palletforks.com not fitting snuggle to kubota FEL
   / palletforks.com not fitting snuggle to kubota FEL #1
312inchmagnum
Port Neches
Kubota L3800
bought some 42" pallet forks for my kubota l3800/la524 quick attach FEL...the spring loaded pins dont fit snuggly at all to the bottom plate part of the pallet fork frame...they fit very snuggly to the bucket that came with the tractor...anyone else have this problem?...solutions?...thanks a ton!
   / palletforks.com not fitting snuggle to kubota FEL #2
Aren't Kabota loaders Skid Steer Style Quick Attach, but not Standard Skid Steer Quick Attach?
i didnt know there was a difference?
   / palletforks.com not fitting snuggle to kubota FEL #4
You can get a small pease of flat stock about 1/4 thick and put it tight up to the pin, then weld in place.
   / palletforks.com not fitting snuggle to kubota FEL #5
Does it pop off? Mine was like that too. I wound up welding a piece of steel on top tighten it up.
Ac
   / palletforks.com not fitting snuggle to kubota FEL #6
I have some Land Pride quick attach for my L4400 and they fit tight tight tight, a bit too tight.
   / palletforks.com not fitting snuggle to kubota FEL #7
That manufacturer runs hot and cold on their fit. Complain and they will likely give you some money back so you can weld the shims in place. I don't know why they just don't make their stuff fit.
   / palletforks.com not fitting snuggle to kubota FEL #8
Many have had the same problem including me. I have not put a piece of flat stock on there yet. Just have to get a welder first.
   / palletforks.com not fitting snuggle to kubota FEL #9
I have the 42" Pallet forks.com ones and they are not an exact build. They are functional, but sloppy. However, the price was by far the best around. If I used them everyday I would go with a better quality fork, but for occasional use they are OK. I also got the bale spear as well with them, but haven't used it yet.
   / palletforks.com not fitting snuggle to kubota FEL #10
I just bought the SSQA setup from the new B3350 tractor - and installed it on my B3200. I also bought a Virnig rock bucket - which is supposedly standard skid steer QA - and the both work fine together. I would imagine that the SSQA setups on the larger tractors - should also meet the skid steer QA standard. The specs for the standard are on the net - look them up and see if the QA on the loader matches up to the standard.
From the picture that was posted - it looks like there's some support missing to push the pallet fork out enough so that the locking pin goes in securely.
Would need better pics to be sure.
2020 JOHN DEERE 7R210 LOT NUMBER 48 (A53084)
2020 JOHN DEERE...
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
2023 Club Car Carryall 700 Utility Cart (A51691)
2023 Club Car...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
