playinsteel
When I purchased my Massey Ferguson 35, the lift would raise and lower, but it was slow and jerky. I just changed the trans/hydraulic fluid and filter and found that there was a good deal of water in the bottom of the case (from old and cracked shifter boots and it was left outside). Now, when I raise the lift, it doesn't want to lower back. If I leave it down when I first crank the tractor, it will stay down, but if I ever raise it, it will not lower unless I depress the clutch or turn off the engine and let it slowly leak down. The lift is still slow, but it's nice and smooth now. I did have the problem just right before I changed the fluid, but I was messing around with the draft lever and got it to go back down. This is my first tractor, so I'm hoping I just don't know how to work it. Anybody have any ideas?
