Outdoor barn light question
   / Outdoor barn light question
I have had a 60 Watt HP Sodium for 13 years.
Yes sodium looks like a good choice. What does the light look like, is it real white like a welding arc, or is it more yellow like an incandescent bulb?
It starts quickly in Wisconsin weather and doesn't make a buzzing sound like some other type I have had.
Good, that's one thing I was wondering about, I have a fluorescent fixture that sounds like a buzz box when it's running. We have a turkey that gobbles his head off any time there's a noise, I don't want him driving me nuts every time the light goes on.
   / Outdoor barn light question #12
We are talking halogen or halide ? Metal Halide is much more efficient than Halogen and is a bright white light.Sodium Vapour gives that awful yellow light. LED is usually a crispy white light. CFL can be anything from pukey warm while , cool white or daylight.
I wouldn't use halogen, too expensive to run. I was looking at metal halide and sodium. I didn't know sodium was yellow, did a little research, turns out the reason sodium appears so cheap to operate per lumen is because its light is at the optimum wavelength to be seen by the human eye. So it "appears" brighter in some biological sense, even though the color of the light may be less than attractive. That perceived brightness is why it comes out cheaper per lumen. I wouldn't use CFLs, I'm still angry that I fell for the BS about how long they would last. They also start fires, I've had one of those little circuit boards start smoking and turn black, so it's the last thing I want in a barn.
   / Outdoor barn light question #14
In that case, avoid the LEDs, too...they also run on a circuit board built by the lowest bidder, and there have been reported issues (shorts, fires). Sad really, for such a promising technology.
   / Outdoor barn light question #15
I like these Stonco fixtures real well. I have a couple in 70 watt but they are available 35, 50, 70 and 100w. I just replaced one lamp that was over 15 years old. :thumbsup:
I guess I should mention they are high pressure sodium.
  • CRESNTE00188_11_125.pdf
I like those, not so industrial looking. thanks
   / Outdoor barn light question #17
I know there have been problems with CFLs but I've had very good luck with them recently. I have them everywhere I can. The outdoor CFL fixture I have on my pole barn cost less than $20 and has been on dawn to dusk for over two years so I think it's paid for itself.
   / Outdoor barn light question #18
Have had a 175 watt mercury vapor light on the big barn for about 30 years. Has worked very well every night and has come back on in many lightning storms. Replaced the sensor and the bulb once in the last 20 years. Have had a 100 watt mercury vapor on the house for about 20 years, working just fine. I had halogen lights over the man doors on both barns, but replaced them with 26 watt CFL light fixtures last fall. Just been through 1 winter, but so far they have worked well. Good light output and hopefully they will last much longer than the halogen. Halogens run hot and seem to be electric hogs. If the CFL's keep working as they are now, I will look at replacing the mercury vapor lights with CFL's when they die if they have a bulb with enough lumens for the 175 watt replacement. Let us know what you decide to purchase.
   / Outdoor barn light question #19
I have a 75 watt HP sodium light fixture placed high up on barn, which is aprox. 150 feet from house and it throws enough light to see your way around the whole yard. It operates from dusk to dawn on a sensor same as street lights. The light has a more orange / yellow cast which I am fine with, cheaper to operate than mercury vapor. The local power company has switched all street lighting to the same HP sodium, 2 reasons cheaper to operate and they also cut through fog better than mercury. We gets lots of fog. I have replaced 1 bulb in the 20 years of operation which cost me about $30 Canadian. The fixture was about $45-50 new. I am not sure of monthly cost, the barn is powered from house, but it does what I need so not concerned. It does need a few minutes to warm up to full brightness, but with the sensor it comes on when needed, so again has not been a problem. It operates 365 days a year in all weather and temperatures, winter / summer. We can get quite cold in winter and it has never failed to start. I have tried the CFL's inside barn and they can't compare, will not light in cold, light intensity low compared to halogen or sodium, and if they break release mercury. So a no go for me, and LED's are still to expensive for initial purchase, but real cheap to operate it wait and see on these.
   / Outdoor barn light question #20
I have had a light at the peak of my pole barn for about 16 years now. Started with a 175 watt mercury vapor light which lasted about 5 years. Replaced it with a HP sodium, which was cheaper to operate and I liked the yellow tint, especially in the snow. It lasted 3-4 years. Then I went with the 200 watt equivalent CFL fixture, which was a disappointment. The sensor lasted less than a year, and the bulb six months after it. So I gutted that fixture, took out the transformer that ran that big bulb and put a new sensor in wired direct to the socket. Put a run of the mill cheap 100 watt equiv CFL in it and its been trouble free for years now. The really cold weather affects the light output but it still comes on every night. I have to borrow an extension ladder to deal with this fixture so the less time spent maintaining the better. I am willing to give LEDs a few more years to become reasonable, the same way it took CFLs.
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2013 VERMEER VACTRON LP555 DT HYDROVAC TRAILER (A52472)
2013 VERMEER...
2014 Dodge Ram 5500 4x4 Bucket Truck with Altec AT40M - 45FT Boom, Jib Winch and Utility Bed (A52748)
2014 Dodge Ram...
2013 International DuraStar 4300 Box Truck, VIN # 3HAMMAAL1DL085200 (A51572)
2013 International...
2007 Hino 268 Truck, VIN # 5PVNE8JVX72S50442 (A51572)
2007 Hino 268...
2010 MACK PINNACLE (A52472)
2010 MACK PINNACLE...
