4wd engagement
   / 4wd engagement #1
arksdad
PA
IH656 - NH T2310 - Country Clipper 60" ZTR
I have a T2310. What is the trick to getting it in and out of 4wd. It's a struggle either way
   / 4wd engagement #2
If you have a loader, raise the front wheels off the ground and it goes in/out like greased lightnin'.:D
   / 4wd engagement
Thanks Jinman, I'll give that a try!
   / 4wd engagement #4
Otherwise, try driving straight ahead and bumping the throttle while applying pressure to the shift lever. The throttle bumping will momentary release pressure on the drive gears. Driving straight will assure no pressure from the differential.
   / 4wd engagement #5
Yup..
   / 4wd engagement #6
Engage and disengage while moving straight. To disengage, 1st accelerate briefly full power - then let off quickly while simultaneously operating the lever.
larry
2018 ALLMAND MAXI-POWER 45 GENERATOR (A58214)
2018 ALLMAND...
UNUSED FUTURE FT-FB30 HYD FELLER BUNCHER (A52706)
UNUSED FUTURE...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A52709)
2021 CATERPILLAR...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
JLG 660SJ (A58214)
JLG 660SJ (A58214)
