JD455 Battery - Go with Optima, JD or other???
   / JD455 Battery - Go with Optima, JD or other??? #1
davefr
Member
Western Oregon
JD 1070
My Optima Yellow Top D51R finally went bad after 10 years in my JD455 Diesel.
I've been happy with Optima but the latest reviews are really troubling with lots of reports of very short life. Should I stick with Optima, go with the JD OEM battery or go aftermarket.
I'm kind of leary of aftermarket L&G tractor batteries because they leak and just don't last long.
Any opinions? Have Optima's really gone downhill in quality?
   / JD455 Battery - Go with Optima, JD or other??? #2
I put an yellow top Optima in an old Nufffield tractor I had 9 years ago. I sold it to my BIL and the battery is still in good shape and he keeps the tractor outside. The length of time they last make them a good deal when you figure I would have had to replace a regular battery at least twice during that period
   / JD455 Battery - Go with Optima, JD or other??? #3
The older Optima batteries were great, I have a couple that are 10 years old. But I have purchases 2 others in the last 2 years and they are not of the same quality. I had heard that Optima was bought by a bigger battery company and well the rest is history. As much as I like the older ones I won't be buying any more.
   / JD455 Battery - Go with Optima, JD or other??? #4
I have three old Optima batteries that are just like the Energizer Bunny!
Odyssey seems to be at the top of the heap now.
Sears Platinum series AGM batteries are supposed to be made by Odyssey.
   / JD455 Battery - Go with Optima, JD or other??? #5
Yes, I have 4 Odysseys. One in a minivan, smaller tractor and two in my class 7 truck. All under 2 years old. Very good, no issues what so ever even after months of storage with terminals connected.
The two batteries in the class 7 truck are very reliable even after multiple cycles of lifting on the power-tail-gate on the back of the truck.
   / JD455 Battery - Go with Optima, JD or other??? #6
I got a optima for my car for Christmas. I had a guy tell me while I was putting it in that there were not any good. He had some for his boat and they did not hold up very well. I have heard the same thing on here, after I got a optima, everyone says a oddyssey is really good.
   / JD455 Battery - Go with Optima, JD or other??? #7
You win some, you lose some, some get rained out, and sometimes you lose the ball in the high weeds. :D
I have an Optima blue top in our horse trailer, but it is not even a year old, so time will tell.
   / JD455 Battery - Go with Optima, JD or other??? #8
I have my fingers crossed. So far I am not impressed.
   / JD455 Battery - Go with Optima, JD or other??? #9
I have a lot of batteries to maintain and don't have the patience or facility to keep these on trickle chargers (over 30 batteries), What has worked for me for the last 10 years since I can't afford to have the premium batteries in everything is to use the Odyssey batteries in my boat, campers and main winter service truck and use the Walmart Everstart in the ones that get cranked up routinely. The Everstart Maxx seems to hold up well enough with routine use and last six years or better in starting battery applications, about $70 to $90 bucks. The Odyssey and Sears Platinum DieHard agm batteries are very good deep cycle batteries but more expensive and the best batteries I have ever had to run campers and trolling motors but they do cost quite a bit more. While I would prefer to have the Odyssey batteries in everything I just can't justify the cost.
   / JD455 Battery - Go with Optima, JD or other??? #10
I splurged and put a yellow top optima (retrofitted) into my 4300 CUT a little more than a year ago. It was awesome. Lots of power and held a charge very well. Then one day it just wouldn't start. I went through lots of troubleshooting and even made a TBN thread requesting help. Tons of suggestions and a few people asked about the battery. To be honest I quickly shot down that possibility as I had already put a charger on it just to see and it showed fully charged.
Sure enough, after a while I pulled the battery and took it to be load tested. bad battery! Fortunately there was a free replacement and I was within the window. I'm on yellow top #2 and it hasn't been two years yet. Without free replacement I'd have replaced with something else. Fingers crossed.
2015 Bobcat S650 Skidsteer - Enclosed Cab - 5462 Hours (A56438)
2015 Bobcat S650...
207278 (A52708)
207278 (A52708)
1985 Ford Ltl9000 Tender Truck (A56438)
1985 Ford Ltl9000...
2019 GALYEAN...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
2017 VOLVO VNL64T TANDEM AXLE SLEEPER TRUCK (A59905)
2017 VOLVO VNL64T...
