1470 mo-co lift cylinder
   / 1470 mo-co lift cylinder #1
corey9212
Red Deer County, AB
2015 John Deere 3046R
Hello, I got my new to me mo-co and got it hooked up to the tractor, so far so good, I go through the hydraulics, hydraulic sway works, but the hydraulic lift doesn't, it is single acting and my tractor manual says to hook it up to the lift SCV and use float to lower attachment. I did that and nothing, I brought my rpm's up and still nothing, I check the rear and the transport guards are off, I've even tried the other lift SCV's with no luck. Anyone got any suggestions on what I could try or what I'm doing wrong?
Thanks.
Corey.
   / 1470 mo-co lift cylinder #2
My old moco had a pin with a clip in it on the other side from the lift cylinder on the back
I'm not sure what happened but suddenly it dropped down and now it's working properly, now I'm having an issue setting the float, it says to set the right from 88-154lbs and the left from 154-198lbs, I imagine its the force it takes to lift the cutting bar up? If so then what do I use to measure the force and when I lift it up I have to push it back down (sticky maybe)
City of Lakeland (A51691)
City of Lakeland...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
PAIR OF DIAMOND PLATE DOUBLE AXLE FENDERS (A51247)
PAIR OF DIAMOND...
2020 KOMATSU PC360LC-11 EXCAVATOR (A51246)
2020 KOMATSU...
UNUSED TOPCAT SSSCR72-72" HYD SOIL CONDITIONER (A51248)
UNUSED TOPCAT...
