Mowing LT133 wans to stall when engine gets hot.
   / LT133 wans to stall when engine gets hot. #1
metoo
sudbury, Ontario
LT133
I have an LT133 lawn tractor and today it started to want to stall when it got hot, let it sit for 1/2 hr and good to go again till it heats up again. My air cleaner is clean.Could this problem be a sensor as the engine gets hot?
   / LT133 wans to stall when engine gets hot. #2
It is the ignition module that is the problem, a common item to fail after time.
   / LT133 wans to stall when engine gets hot. #3
Have you ever removed the shroud and checked for a mouse nest that could be obstructing air flow?
   / LT133 wans to stall when engine gets hot. #4
Try something simple , loosen the fuel cap as soon as it stalls out see if it starts again.
The L and seems to be most other series have a problem with the fuel cap vent plugging up. I think it is related to the ethanol in the fuel but regardless, clean out the small vent in the cap.
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
2015 HYUNDAI TRANSLEAD TRAILER (A59575)
2015 HYUNDAI...
2011 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A59575)
2011 FREIGHTLINER...
2004 INTERNATIONAL 7400 20FT TANDEM AXLE FLAT BED (A59575)
2004 INTERNATIONAL...
2004 DCT PUMP TRAILER (A58216)
2004 DCT PUMP...
