OK, so I bought my first Tractor...pictures coming...but...
   / OK, so I bought my first Tractor...pictures coming...but... #1
Madison, Ga
Kubota L3200HST with LA524 Loader, Quick Connect; Loaded R4 Tires
now I need to figure out how to use it I'm trying to find information on basic tractor operations. Things like, the best way to fill a bucket and work a pile, how to use a box blade on a gravel driveway, how to get a smooth compacted path using a loader when filling in a ditch, the best way to use a bushhog, etc.
Can anyone point me to a training course or other forum where I could learn? Pictures would help a great deal.
   / OK, so I bought my first Tractor...pictures coming...but... #2
   / OK, so I bought my first Tractor...pictures coming...but... #3
Some basic instruction will be in the manual that comes with the tractor...at least for the loader.The box blade is a great tool with a little bit of a learning curve.If you purchase a new Bush Hog,it also will have a manual.Lots of good reading on this forum and don't be afraid to ask questions.A lot of it will just be "hands on"/practice.I had run older gear shift ,gas tractors....these new tractors are leaps and bounds better and easier,also safer.With HST you will hardly ever use the brakes.
   / OK, so I bought my first Tractor...pictures coming...but... #4
With HST remember...let up on the "go" pedal for more power....not down like a car/truck.My normal working RPM's is about 1800.
   / OK, so I bought my first Tractor...pictures coming...but... #5
Operating instructions for the FEL will be covered in your Kubota FEL Operator's Manual.
For the other information learn to use the SEARCH function here on T-B-N.
Also spend time on the SAFETY Forum.
Learn to use the FEL first, then the box blade. Delay on the 'hog until you have mastered the first two. Hooking up a PTO is always a challenge and a 'hog is a relatively hazardous implement as the spinning blade has tremendous kinetic energy.
An L3200 is a pretty good sized "first" tractor. Go slow at first. Get off the tractor when you are hot or tired.
   / OK, so I bought my first Tractor...pictures coming...but... #6
Everything Attachments has good videos on just about every aspect of tractoring and implements.
Tractor and Skid Steer Attachment Videos
Also, You Tube, has informational videos - most of them are believable.
Edit: Darn, TripleR beat me to the EA videos.
   / OK, so I bought my first Tractor...pictures coming...but... #7
Some of them are good on You tube.. but an awful lot of them are "bobby trying to use the Front End Loader" videos.. and show a lot of bad habits. like keeping the Front End Loader up as high as you can get it and traveling with a load that way, and of course no Ballast on the 3pt. I have seen a bunch of things that would scare the heck out of me, and I have been using FEL's and tractors for over 20 years.
   / OK, so I bought my first Tractor...pictures coming...but... #8
Yes, without turning this into a safety police infomercial, there seems to be a certain "you can't teach me cuz I don't want to learn and we've always done it like that" mentality that continues in certain environments. About once every year or so I or a buddy will see someone straddling a 3pt auger for extra weight whiles its running, despite the fact that in fairly recent history there was a worker who had both arms and both legs torn off by doing the same.
Ignorance can be fixed; stupid goes to the bone.
Unused Delta Crash...
2009 Ford F-650 24 ft Box Truck - 6.7L Cummins L6 Engine - Automatic Transmission - Low Mileage (A52748)
2009 Ford F-650 24...
2018 Freightliner M2 106 Cab and Chassis Truck (A51692)
2018 Freightliner...
Pallet Fees (A50775)
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
Two Post Car Lift (A50120)
Two Post Car Lift...
