22ft beaver tail hauler mod to 101" to haul hay baler
   / 22ft beaver tail hauler mod to 101" to haul hay baler #1
countryguy1225
Fenton, Mi
Kubota M6060 & L2550GST(4wd), W/ Backhoe attch. Mitsubhish MT160D (4wd) :- )
Hi all,
I normally hang out over in the Hay forum on TbN. But I wanted to share a story and get some feedback. This all starts with a car hauler. This hauler is a mid wheel standard hauler. NOT over a top-over deck due to expense and practical use. To haul the hay baler we found out the axle length was ninety something inches!! We are not wide enough!
I said to the misses- don't worry. We'll just modify/extend the deck outwards 8" on each side from the wheelwells back. Should not be a big issue?...
Off I went for 1/4 Steel to make my decking. I woul use 8 gussets/braces per side holding up 8" wide flat plate for that new deck. Something like 6' long of new decking total to get from the back on-ramps to the wheel wells.
I tried a 14" cutoff wheel and after 2 hours realized that this was a much bigger job than I thought! I called in my brother the machine builder..... He sort of laughed at me and said I needed a large metal saw (horizons band-saw thing) or a PLASMA CUTTER.
Here is where the story gets fun! I haul out to Harbor Freight to get us the cutter! We get home, fire it up, and WOW, HOLY COW, I AM IN LOVE (big ol' grin).
This thing cut through that 1/4 hot rolled like butter! To test the cutter I even doubled up to 1/2" steel plate and it popped thru that too.
My brother started to built and weld the sections w gussets and plate tops in no time flat!
As I look into this further, I am finding a solid need for some flatbed car haulers to also offer a combo 101 decking surface with out going to a more $$ top over trailer type. I wonder if there are any out there?
So that is the story of a new 22' sure trac car hauler that wants to haul a hay baler.
Happy 4th to everyone!
   / 22ft beaver tail hauler mod to 101" to haul hay baler #2
speaking of which, anyone know were to get stock side swing brackets?
i thought about adding them to my equipment trailer to make it wider to haul wide stuff (bailer mostly)
   / 22ft beaver tail hauler mod to 101" to haul hay baler #3
Hi all,
So what is the stock number of the thing you got from HF. Just curious.
   / 22ft beaver tail hauler mod to 101" to haul hay baler #4
The only time I've seen them from the factory was on heavy low boy equipment haulers. Wouldn't be hard to make though.
   / 22ft beaver tail hauler mod to 101" to haul hay baler #5
how about some final pictures? AS you know it didn't happen if there are no pictures! Did the additional width work for you?
Hotsy Pressure Washer (A51573)
Hotsy Pressure...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2017 Mower Max Flexwing Mower (A51573)
2017 Mower Max...
2019 Ford F-450 Utility Truck, VIN # 1FT8W4DT8KEF27612 (A51572)
2019 Ford F-450...
