welding on a set of pallet frks
   / welding on a set of pallet frks #1
logankelly
winona mn
jd2520
the set of forks I have they slide back and forth on a round solid bar. there is a lot of play in the forks. found some steel bushing that fit over round bar but would the welding hold if I welded to the top of forks? y
   / welding on a set of pallet frks #2
If the forks are made out of T-1 it might be best to figure out a way to mechanically hold the bushing in place. With set screws or something.
When I made the fork attachment for my tractor I used all mild steel, and box tube for the forks. I welded small clips to the back board so the forks stay in one place.
   / welding on a set of pallet frks #3
What problem does the extra play cause? Can you go to a larger bar?
I got this bar free from a cylinder repair shop because it was bent. It is about a half inch smaller in diameter than the hole in the forks and works good.
2003 Chevrolet 3500 (A50120)
2003 Chevrolet...
22ft T/A Enclosed Cargo Trailer (A51694)
22ft T/A Enclosed...
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
2011 Ford F-350 Knapheide Service Truck (A51692)
2011 Ford F-350...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
Tradewinds Power Unit (A50120)
Tradewinds Power...
