In general, I think kubota numbers are underrated. But before anyone flames me, lets go over a few things.
First and foremost, the loader manuals (at least mine) has a nice graph picturing lift capacity. And that graph is an arc. Just like the loader lifts in an arc.
As you raise the loader, the cylinder to loader arm angle/relationship changes. So the higher you lift, you actually have LESS capacity.
Notice that JD loaders list a spec @ midpoint (59") and then a LOWER spec to max height.
Also, as to kubota loader numbers, it is correct that the number is what they can lift in kilos, BUT, technically not the last number. The last number gets substituted for a 0 as what it really represents is the series.
IE: MY loader is a LA463. It can lift 460kg and it is the 3rd series of that loader.
Also, that number is at bucket center (which is realistic of loading a bucket load of material). But the newer models I think are going to the pin measurment. The loader that relplaces mine on the
L3800 is the LA504 IIRC. So 500kg and 4th series. Thats 1100lbs, and THATS the pin number.
But its always a good Idea to check the actual spec online and NOT just rely on model number.
Now some real world.....I have a LA463 that is only supposed to lift ~860lbs at the bucket cutting edge. I have lifted and moved my 500gallon propane tank with some propane still in it, with nothing more than a chain right up and over the cutting edge. Approximate weight 1500#
I also lifted my bushhog 306 cutter off the trailer when I got it, and the manual says 1100# for it.
Then we can get into a whole other can of worms in that if you cannot lift an object, you can curl and actually lift it that way....
