Loader Loader bucket stuck
   / Loader bucket stuck #1
James Thomas
Alabama
Massey Ferguson 1250.
i have a Massey Ferguson 1246 FEL and a MF 1250 Tractor. The loader is stuck half way up. Will not raise up or down. The tilt mechanism works just fine but no up and down motion for the bucket itself. What areas should I look at for the culprit and is it a major repair? Can't find any leaks or bad hy..hose connections. thanks..James
   / Loader bucket stuck #2
Look at your couplers... and the linkage for the control levers (if any)
   / Loader bucket stuck #3
Is the spool moving for the lift circuit?
Check for a blocked QD.
Go to float and see what happens.
An open return path is necessary for any cyl fluid to flow.
Block the flow and the cyl will lock.
   / Loader bucket stuck #4
Before you do anything...remember that the loaders will fall if pressure is released...so, be very careful
I strongly suggest you block up the loader to prevent it accidentally dropping
Thanks, had too much fluid in the reservoir which increased pressure then blew a coupling out. Drained some fluid via filter and hooked coupling back up and all works fine now. A stupid mistake...I misread the dip stick. Thanks for all replays
Blew a coupling..too much fluid..too much pressure. All fixed now..Thanks!!
   / Loader bucket stuck #7
Glad that was all it was.
2007 Ingersoll Rand G240 240kVA 3-Phase Towable Diesel Generator (A59228)
2007 Ingersoll...
2013 Ram 1500 Crew Cab Pickup Truck (A59230)
2013 Ram 1500 Crew...
2014 GMC Sierra SLT 4x4 Crew Cab Pickup Truck (A59230)
2014 GMC Sierra...
2017 PJ TRAILER 20' T/A TRAILER (A58214)
2017 PJ TRAILER...
2007 KUBOTA KX121-3 SUPER SERIES EXCAVATOR (A60429)
2007 KUBOTA...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
