MF35 governor
/ MF35 governor #1
furgusonman
MF35 1961
Hi,I have a mf35 with z134 gas engine,I just bought this tractor I have a problem with power. It runs good but when I drive it and start going up a small hill it try,s to stall. If i give it more gas it keep,s going and runs good.I looked at the governor assembly and the part where the round disk with the ball barrings in it has been replaced with what looks like a piece of leather.Do,es any one know if this could be my problem? :confused:THANKS :confused:
/ MF35 governor
I guess no one knows any thing about my governor problem.Owell worth a try thanks anyway.
/ MF35 governor #3
G'day just wondering which part of the govenor you are referring to ?? The only place i can think of that you would be able to put a leather disc is on the bottom of the throttle shaft under the bett box, if this is so then this is not part of the govenor as such. The govenor is run off the front of the camshaft ( unless i am thinking of a different engine:confused2:) and has a link running to the carb from a shaft coming out the timing cover at the front of the eng. Inside the timing cover there is a flyweight assy that does have a habit of breaking the mounting pins as well as the weight mounts. Can you post some pics of what you are talking about and don't get discouraged so easily sometimes it takes a while for someone to see your post that can help you out ( don't know if i can or not but i will try:thumbsup:)
Jon
/ MF35 governor
Hi' let me ask what is probably a dumb question,but im not good with computers.How do i upload a photo or whatever it's called Thanks again
/ MF35 governor #5
G'day sorry you are asking the wrong person bout that:confused2: i am pretty well computer illiterate except for being able to find the sites i want to go to and typing out a few responses. Maybe if you put a queston in the general forms somebody can help you out with that:)
Jon
/ MF35 governor
Hi,i think i figured out how to post a photo i hope.OK here goes in the photo you can see the round disc with the leather sticking out.Is this the governor assembly that i see on line with the ball barrings in the disc? Also if you can see the small bolt with the two nuts on it some one replaced what ever was there with the bolt.Do you think any of this would be my problem? One more thing do you know if the little screw on the left side front of the engine that goes in the cover for the i think part of the governor what it adjust es? Also do you know any where on line where i might find a diagram of this stuff? Any help is greatly appreciated.I hope my img works and thanks again.
/ MF35 governor #7
G'day fergusonman great pic at least we have now got somewhere to start. The round disc in your pic is there as a friction disc to stop the hand throttle from vibrating back to idle from where you set it if it is not doing this ( going back to idle by itself ) then this part is ok, the bolt with the two nuts is just replaceing a pin that was prob worn or fell out so that is ok. The screw coming out of the timing case ( should be on the right side of the eng from the operators seat facing fwd ) is the full eng governed speed setting from memory and should not need adjusting. If you pull the throttle wide open the governor should control engine rpm to about 2500 - 2700 rpm. With the eng stopped check the governor linkage by hand and make sure it is moving freely it may just want some lube
Jon
/ MF35 governor
Hi' thanks for your help i have been working on my governor problem again,i checked all the linkage and lubed all the moving parts.Now when i start it up it starts to rev up to about 1/4 throttle i can push the hand throttle up and it goes back to idle.i have disconnected the linkage from the carb to the gov,arm and it still revs up,i can push the gov,arm back by hand and it will go back down to idle when i let it go it goes back up.im starting to think it might be internal where the governor assembly goes.do you or any one else know of any thing else to try to fix this thing, im getting a little frustrated at this thing.if i need to go inside is it a major and pricey job,what all will i need to replace? "thanks for any help"
/ MF35 governor
Good evening sorry for the second reply but i have been troubleshooting the 35 gas,and i have made "SOME" progress.I took all the linkage apart and reassembled it with some more lube and it works mush better, maybe a little more tweaking.Now my main problem is the governor not coming in under load like i replied in my previous reply does any one think like me i need to go to the internal part, and if so what and do i need to replace.Sorry for the second reply but i thought it would help.Thanks again for all the help.
/ MF35 governor #10
I have a MF 35 with a governor problem. I can start it fine, but then it goes to full throttle. I have to keep working the throttle lever to control it.
any ideas?
/ MF35 governor #11
have you read this thread?
/ MF35 governor #12
any ideas?
First off WELCOME.... you resurrected a 3 yr old thread so responses may be slow
I your engine is running away you need to check the linkage to be sure it is connected and not binding in any way. Or you could have lost the balls that are in the race that are in the governor itself its on the front of the engine behind the timing cover.
My Mf35 lost the race and balls, Replaced and all was well again.
/ MF35 governor #14
Thanks for the Info. I'll give it a try
I'm assuming your working with a repair manual. If not please donot take apart the governor without prior knowledge or you will create more problems. You can goto www.agocpartsbook.com and login as GUEST and lookup your tractor. There you will find exploded parts diagrams for every area of your tractor. You can at least see how the linkage is attached to the governor. You can print the illustrations thru Internet Explorer with Microsoft Silverlight installed. The site also displays parts numbers alongside the illustrations hence the name AGCOPARTSBOOK. Then you search thru Google for accurate proceedures to adjust the governor on a MF35. BTW Welcome to TractorByNet. At the top of the forum page there is a Google search engine to search this site for the info you seek. I'm sure this topic has been covered at one time or another. Get those hands dirty.. :laughing: -kid
/ MF35 governor #15
any ideas?
Remove the power steering pump cover on the flange on the left hand side of the engine block just behind the timing cover. It has three screws holding it on. Reach in and feel for the cup and shaft assembly of the govener. Move it forward with your fingers and move the throttle shaft coming out of the timing cover, if there is free play, back off the adjusting screw nut and turn the screw in one half turn at a time and note if the free play is reduced. Note how many turns you move the screw in case there are other issues. If you notice improvement keep turning the screw in a little at a time and stop when the free play is gone. Remember to have that cup assembly pushed as far forward as possible. Once you have the free play out, put the power steering pump cover back on and start the engine. It should not over rev and you should have better speed control. You may need to screw the adjuster in about a eight of a turn at a time until the motor does not surge. Remember to tighten the locking nut on the adjusting screw. If you cannot get the free play out with the adjusting screw, there is a spring acutuated by the adjusting screw that may be missing or broke. This will involve removing the radiator and timing cover.
/ MF35 governor #16
I am assuming that you have a Continental gas engine and not a diesel. After I reread the thread and found that it was the OP that had the Z134 engine, I have to clarify these suggestions pretain to the Continental engines and not the Perkins diesel engine. Hopefully there has been no confusion. Sorry.
/ MF35 governor #17
My MF 35 has more problems then the governor. I was mowing with it, when I heard a sound like a chain dragging. I shut it down to see if I hit something with the mower deck,but didn't. Tried to start it up again but no go. I'm thinking timing chain. How do go about checking or replacing it?? never tried this type before. Need some input.
UNUSED SDLANCH SDLGC100 ELECTRIC GOLFCART (A60430)
UNUSED SDLANCH...
New Holland 650 Hay Baler (A53317)
New Holland 650...
2017 CATERPILLAR 420F2 BACKHOE (A60429)
2017 CATERPILLAR...
John Deere 3025E (A53317)
John Deere 3025E...
207280 (A52708)
207280 (A52708)
UNUSED 2023 VOLVO ECR25 ELECTRIC EXCAVATOR (A60429)
UNUSED 2023 VOLVO...
