Sae 30 desiel oil in small gas engines??
   / Sae 30 desiel oil in small gas engines?? #1
HogJawHoller
Winfield, WV
Mahindra 5035HST
Is it ok to run sae 30 for Desiel engines in gas engines that call for sae 30?? I was guessing it was ok. Big box store man seemed to agree. Thx
   / Sae 30 desiel oil in small gas engines?? #2
The Kohler engine oils are also diesel rated, so there shouldn't be any problems with running diesel rated oil in a gas engine.
Thanks randyT! I have several Koehler engines I was going to use it with. Thx
   / Sae 30 desiel oil in small gas engines?? #4
Run Rotella 30 weight in my B&S mower and tiller engines for several years. None have ever blown up yet:).
   / Sae 30 desiel oil in small gas engines?? #5
Main difference between diesel rated oils and gasoline rated oils is ability to hold soot. So, using a diesel rated oil in gasoline engines is fine. Could even use a gasoline rated oil in a newer diesel for a shorter-than-recommended change period.
   / Sae 30 desiel oil in small gas engines?? #6
A lot of oils have both a "C" rating for diesels and an "S" rating for gas engines. Read the label.
CATERPILLAR 631E SERIES II MOTOR SCRAPER (A52706)
CATERPILLAR 631E...
2017 PETERBILT 579 (A53843)
2017 PETERBILT 579...
LATE MODEL JOHN DEERE EQUIPMENT AUCTION (A53084)
LATE MODEL JOHN...
UNUSED Grey Waterproof PE Tarpaulin w/Grommets (A53117)
UNUSED Grey...
2020 Kubota RTV-X1100CW-A (A47384)
2020 Kubota...
Tiger Mower Hydraulic Tank Connection (A51691)
Tiger Mower...
