Mahindra 4500 PTO coming engaged
   / Mahindra 4500 PTO coming engaged #1
Offshoredoc
I have a 4500 with 450 hours on it. When using the PTO, it occasionally disengages. To re-engage, you have to clutch in ALL the way instead of just being able to clutch in a small amount.
Anyone have any suggestions?
Yes, it is a 42hp 2wd without a FEL
   / Mahindra 4500 PTO coming engaged #4
Your tractor has a 2 stage clutch, and the pto portion of it, is not disenguaged until the pedal is pushed all the way down. I believe the clutch is operating properly.
Any idea what could be the issue?
Bump...
Bout to start bush hogging again and I've still got the problem. Was told the lever may be bent which is keeping the PTO from engaging. Any suggestions!
   / Mahindra 4500 PTO coming engaged #8
I've got the same tractor. No problems with it disengaging but I do have to slide the lever back and forth til it finds it's happy spot and will crank. Good luck.
   / Mahindra 4500 PTO coming engaged #9
If you let the clutch out when trying to enguage it, does it grind?
Yes it does grind, even when clutching it ALL the way. Sometimes I can get it to not grind if I step on the clutch hard.
(4) 320 x 90 R50 Tires and Rims (A50514)
(4) 320 x 90 R50...
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50774)
WE DO NOT...
2000 JOHN DEERE 310SE BACKHOE (A51242)
2000 JOHN DEERE...
2007 Toyota Camry (A50324)
2007 Toyota Camry...
CASE 850M WT CRAWLER DOZER (A51242)
CASE 850M WT...
2019 GEHL RT105 SKID STEER (A51242)
2019 GEHL RT105...
