MHarryE
Elite Member
- Joined
- Feb 15, 2009
- Messages
- 2,975
- Location
- Northeastern Minnesota
- Tractor
- Kubota M7-171, M5-111, SVL75-2, RTV900XT & GR2120; CaseIH 1680 combine
Diesels don't have a stociometric fuel ratio like gasoline engines (Otto cycle vs. diesel cycle). Gasoline engines are throttled to take in only the amount of fuel/air mixture needed (or on the latest engines with direct gasoline injection still limit the air to get the proper ratio. Diesels are I throttled, always take in a full charge of air, and inject only enough fuel to meet the power need. At low power there is a lot of unused oxygen in the exhaust. Whomever said running a diesel lean will blow the engine needs to Google diesel cycle and read up. The Otto cycle is heat added at constant volume I.e. top of stroke. Diesel cycle is heat added at constant pressure - top of stroke begin burning fuel to hold a constant pressure as the piston moves down. Of course actual design does not match the perfect cycle pressure diagram. And always adding politics to set blame. If you look at the standard the date it was signed was May 11, 2004, and I do not believe Obama was president at that time. But the question about turboing the 2.0 liter V-2003-V engine - Kubota does not supply a 2 liter turbo engine in their pre 2013 engine lineup. The V series doesn't come with a turbo until 2.4 liter - according to Kubota anyway.
