mower deck pto box lube button
   / mower deck pto box lube button #1
KestrelMerlin
Member
PA
John Deere 2305
I just took the deck off the JD 2305 to clean it and sharpen the blades and got to thinking about the push button on the gear box. :confused: Thinking does not work as well as it used to, so I have this basic question. How does that thing work?
When I got this tractor - my first - about a year ago someone told me what it means when you push it down and it pops right back up, but I don't remember what they said. I tried searching on this forum, but no joy.
So I'm putting my embarrassment aside and asking for your help. Thanks for any info you have!
Since there have been over 100 views and no comments, maybe I should clarify. I think that the button I'm talking about is to check the status of the lube inside.
I'm guessing that there is a small float inside that makes the button pop up. Maybe if the lube level drops, the button will not pop up after being depressed.
   / mower deck pto box lube button #3
For best results,try posting on the John Deere Owning/Operating Forum.They will be able to help you!Good Luck!
   / mower deck pto box lube button #4
I would help you if I could.. but I don't have a clue:confused3: Sorry
James K0UA
Thanks, number two and ku0a. I thought it would be a common feature on tractor and implement gear boxes, so I posted here. I know there are a lot of very helpful people who watch this forum.
   / mower deck pto box lube button #6
The owners manual doesn't say anything about the button on the gear box?
Didn't come with an owner's manual. Thanks anyway.
   / mower deck pto box lube button #8
If it is John Deere equipment, all the owners manuals are available online on their website.
2018 FORD F-150 XL CREW CAB TRUCK (A51406)
2018 FORD F-150 XL...
(INOP) KUBOTA L2550 TRACTOR (A51247)
(INOP) KUBOTA...
UNUSED WOLVERINE TL-12-72W 72" HYD TILLER (A54757)
UNUSED WOLVERINE...
CURTIS 55CFM AIR COMPRESSOR (A54757)
CURTIS 55CFM AIR...
