Drainage ditch using a MB/SS.
   / Drainage ditch using a MB/SS. #11
I would use 4" minus diameter crushed rock for erosion control. 4" minus means that at least 60% is 4" and the other 40% is a combination of rock smaller that 4" which usually fills the voids well. Crushed stone also locks together well so it stays in place better than round river rock.
   / Drainage ditch using a MB/SS. #12
thanks Gary
about how deep should I put in
the trench I put in is only about 8" deep
and what about side erosion?
Ive thought about rip-rap, but ive temporarily put about 5 yards of large sandstone in some key areas to serve as check dams. With all our rain here lately i will put down some bermuda seed and hopefully get it started before the growing season ends in October
   / Drainage ditch using a MB/SS. #14
thanks Gary
Normally if you just cover the ground with one layer of stone it will hold up well. The sides need to be slightly rounded up so you can lay the rocks up the edge. Some of this might require hand work to place them without adding a lot of material to the ditch. You should dig the ditch deep enough to allow the placement of the 4" layer of rock in the bottom and sides.
(INOP) FORD 7710 TRACTOR (A51247)
(INOP) FORD 7710...
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 (A55787)
2016 New Holland...
UNUSED IRANCH WROUGHT IRON SITE FENCE (A57193)
UNUSED IRANCH...
SINGER 211 UPHOLSTERY SEWING MACHINE (A54757)
SINGER 211...
Utility Tilt Trailer (A55787)
Utility Tilt...
2022 Wacker Neuson LTV6 Towable Light Tower (A55851)
2022 Wacker Neuson...
