Holes in dash
   / Holes in dash #1
GEOFFP
Seaham,NSW, Australia
MF135 Diesel (1969)
Cqan anyone tell me what the holes in the lower left side of the dash are used for on my MF135 diesel?
   / Holes in dash #2
Which hole are you referring to? Gauges? -kid
   / Holes in dash #3
Welcome to TBN, is it a slot with a bolt hole on top and bottom?
   / Holes in dash
The holes are on the lower part of the dash, on the left hand side, not the guage holes, its below that. I tried to attach a pic but couldn't get it to happen. The upper hole is on a radius, it is about 1"wide and 3" long, curved around from 11o'clock to 1o'clock on a 3" radius. In the what appears to be the centre of the radius, there is a round hole about 1"diameter with a rectangular cut-out on each side. Sort of like a head with ears. Hope this helps, I'll try again to attach pic.
Geoff
   / Holes in dash
   / Holes in dash #6
That looks like the original key switch hole. Man I don't know that dash has been cut up a lot.
   / Holes in dash
Thanks Murph, I thought the dash was pretty standard apart from those holes. I forgot to mention, the holes are very neat and tidy, obviously factory-made, not home-made. I guess I'll keep looking and if I haven't found anything by the time I get to restoring the dash I'll just blank the holes off. But I am curious to know what was there.
Geoff
   / Holes in dash #8
Geoff
I've been looking for photos with like options and haven't found one yet. I'm thinking that was where the turning signal mechanism was mounted. You must keep this in mind. They drove these tractors like cars with cabs, heaters,wipers, and turn signals. UK version tractors had more options on them to be road worthy.
   / Holes in dash #9
Good catch Kid.
   / Holes in dash #10
Could be a place for a choke cable for the gas version and also a starter bottom. Some tractors had a separate starter button
202479 (A54757)
202479 (A54757)
More info coming soon! (A55787)
More info coming...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A55315)
2023 Unverferth...
2004 GMC Sierra 3500 (A55973)
2004 GMC Sierra...
2020 KENWORTH  T800 KILL TRUCK (A58214)
2020 KENWORTH...
2003 Ford E-250 Wagon Passenger Van (A56858)
2003 Ford E-250...
