95 F350 power steering pump issue
   / 95 F350 power steering pump issue #1
Newblue
Gold Member
Central Indiana
New Holland TC45DA SS
95 F350 2WD, 460 motor. When the engine is off and the steering wheel is turned, the fluid in the reservoir will pop the cap off and spray fluid under the hood. It works perfect when the engine is running and the steering wheel is turned. With the front jacked up I can grab the rotors and run it lock to lock and no fluid will come out. This has me puzzled.
   / 95 F350 power steering pump issue #2
Has to be a stuck check valve or pressure relief valve.
How much is a new pump?
Chris
   / 95 F350 power steering pump issue #3
Had a similar problem on at least one of my old 88-91 F250/350 trucks. Replaced the cap and it solved the problem (although as Chris suggests it may be more involved than that)
The caps have little plastic locking lugs that flex and weaken over time.
250ft Roll of Copper-Clad Aluminum Building Wire (A55852)
250ft Roll of...
Honda EM4000SX Portable Gasoline Generator (A55851)
Honda EM4000SX...
2005 Kaufman Trailers Car Hauler Trailer (A53421)
2005 Kaufman...
SAMSUNG REFRIGERATOR / FREEZER (A54757)
SAMSUNG...
2016 Ford F-250 4x4 Reading Service Truck (A55852)
2016 Ford F-250...
PALLET OF HYD HOSES (A57192)
PALLET OF HYD...
