LT160 loses power going up hill
   / LT160 loses power going up hill #1
firefighter4u
Bradford, Pa
John Deere LT160
I recently purchases A LT160 and am having issues with it losing power as I traverse up slope. During my research I discovered that the type of transmission it has is prone to fail (the mower has 325 hours on it). I replaced the pump, motor, filter, vent plug and added 5W50 synthetic oil to the the hydro. Unfortunately it did not help the problem at all. The drive belt shows some sign of cracking but not in terrible shape. Non the less I just ordered a new belt to replace it. The engine starts fine, runs fine, doesn't seem to burn oil (just changed oil, filter and spark plug). My yard isn't that steep, in fact my neighbors d140 runs right up it so I know i am not asking too much of the mower. The overall condition of the mower is very good. I would appreciate any suggestions that you may have to remedy my situation!
   / LT160 loses power going up hill #2
My brother's was doing that. I found some play in the hydro linkages and after taking the slop out, it now works fiine
   / LT160 loses power going up hill #4
"Power" as in loading down the engine or just quiet loss of speed?
If it is indeed the transmission worn that seems unlikely with only 325 hours, but I am not familiar with that mower.
So far as I know mine does not have and adjustment inside, only the linkage.
Loss of speed mostly. The engine sounds like it takes on a load but only slightly.
And how exactly would you adjust the linkage?
   / LT160 loses power going up hill #7
I don't think it would be so much as adjusting. Not sure on that model though. All the linkage that is involved from the pedals to the transaxle should be checked for any wear/slop. When you depress the pedal,the linkage should move accordingly.
Greg
Ok gotcha, I'll check that. Thanks!
Ok, after replacing the drive belt (along with some adult language due to frustration) I tested it out and there is no difference. In fact, the hydro is now slightly making that "whine" sound that you often hear in older tractors. I did not get a chance to look at the linkage as it was getting dark, perhaps tomorrow. Not sure what else to check. Perhaps I'll do a compression check tomorrow as well. Still frustrated with this thing, but not giving up just yet!
   / LT160 loses power going up hill #10
The transmission on my LT180 was doing the same thing around 400 hours. I replaced it with a new one ($900) and it has been good sofar (650 hours).
10' Fork Extensions (A53316)
10' Fork...
2017 Ford F-150 Crew Cab Pickup Truck with Liftgate (A55852)
2017 Ford F-150...
2010 MULTIQUIP 25KW GENERATOR (A53843)
2010 MULTIQUIP...
2010 Club Car Precedent Electric Golf Cart (A55758)
2010 Club Car...
2011 DOOSAN G25KW GENERATOR (A53843)
2011 DOOSAN G25KW...
UNUSED IRANCH HYD EXCAVATOR THUMB CLAMP (A54757)
UNUSED IRANCH HYD...
