New DK45SE vs Used DK40/45SE
   / New DK45SE vs Used DK40/45SE
Well I'm new to all this and didn't know it even had stands. But the links I'm talking about are about 12" long and have a large pin going through both ends. There were two per side. The outside ones were tight and the inside ones both could be wiggled by hand. I'll try to find a picture...
Also, there were three buttons for the pto. The right button was for on/off. The middle button was manual/automatic. Neither I nor he salesman (kubota) knew what the left button did. It had a profile picture of a tractor with the pto underneath. I'm guessing its for a mid-mount pto? It was 100* outside and I forgot to investigate further.
Thanks,
Barry
   / New DK45SE vs Used DK40/45SE #12
Thanks,
Barry
It sounds like you are describing the stands. The third switch, the left switch is the cruise control switch. If it has the Mid PTO there is a little lever near the floor to actuate it. If it is not equipped, there will be a plug in that location.
James K0UA
The links I'm referring to are the banana shaped ones that sandwich the ends of hydraulic cylinders in the picture. (I really hope the picture uploads.)
Thanks,
Barry
   / New DK45SE vs Used DK40/45SE #14
The half moon metal pieces you referred to are going to rattle at times, especially if there is nothing attached to the QA, (quick attach) bracket(s). As long as they are not bent, (more closed than they should be), and not twisted from being over-stressed then you should be good. And if the pins are not well greased then they could rattle.
I had problems with them on my DK-35, but it was mostly over-stressing them, and being an inexperienced operator in need of the next model up. When I went to the DK-40 and the much stronger KL-401 loader I now have no issues with them.
I went and bought it this morning. Paid $14,300 and its scheduled for delivery tomorrow afternoon. Now to order a grapple...
Barry
   / New DK45SE vs Used DK40/45SE #16
Barry
You got a lot of machine for the $!
   / New DK45SE vs Used DK40/45SE #17
I don't know squat about used Kioti prices, but that sounds like a great deal to me. Enjoy.
   / New DK45SE vs Used DK40/45SE #18
Time to read your owners manual.
   / New DK45SE vs Used DK40/45SE #19
Barry
Congrats on the new purchase. :thumbsup: Welcome to the pack!
I'm up to section 10 now. Then there is the loader manual also.
Thanks for all the feedback, it's what makes this forum so good.
Barry
2019 MACK P164T WINCH TRUCK (A53843)
2019 MACK P164T...
2001 Ford F-250 Pickup Truck (A55852)
2001 Ford F-250...
2019 Ram 1500 4x4 Crew Cab Pickup Truck (A55852)
2019 Ram 1500 4x4...
2015 BMW 328i Sedan (A55853)
2015 BMW 328i...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
