It was a TORO GROUNDSMASTER 217D
   / It was a TORO GROUNDSMASTER 217D #1
JoBy
Timra
Toro
I bought a TORO GROUNDSMASTER 217D with a minor problem. A connecting rod had punched a hole in the engine block.
I took it apart.
After searching for another engine for a while I finally found a donor vehicle.
The Ford engine was only 4cm ( 1.5 in ) longer than the 2 cyl Mitsubishi diesel.
Fabrication starts ...
I removed this box ...
I had to find a new place for the alternator.
A new custom pulley that bolts to the TORO pulley.
And it is running again!
It started snowing so I made a simlple snow plow.
I had an old radiator and decided to make a slightley more serious snow plow from that. I used electrical actualtors to turn the blade.
Summertime and I needed a wheel loader instead. Very simple but it was much better than digging by hand.
Well, it seems like it want's to be a wheel loader ... time to get serious
An hydraulic pump, and a new pulley on the flywhleel.
A tower behind the seat.
Got some parts laser cut.
Building the lifting arms.
And the tilt mechanism.
DSC_0225.JPG DSC_0226.JPG*
I made an XY lever for the valve body
And a small video if the XY lever.
[video]http://www.joby.se/toro/xy-spak.avi[/video]
   / It was a TORO GROUNDSMASTER 217D #7
Wow I am impressed! :thumbsup:
Yours took a lot more work than mine. I have never seen a tilt system like that.
Glad that I inspired you to build it.
Tried to watch the video, but don't have the right codec for Windows Media Player.
Looking forward to the rest of the build pictures.
The tilt works very well. It has almost the same strength thru the whole movement, and it also has a lot of movemet. I can tilt the bucket almost straight down at maximum lift.
With the tilt cylinder at the rear I can also get the bucket closer to the front wheels.
Actually I found your pictures 2 years after I built mine.
This is the same video of the XY-lever uploaded to youtube:
Some more pictures of the hydraulics as it was when I first bulit it. ( It is a bit more complicated now :confused2: )
And a video showing the tilt mechanism with the rear mounted cylinder.
Moving some heavy wet snow. It will get a bit light at the rear when I get about 360 kg ( 800 lb ) in the bucket. The hydraulics will lift over 400 kg ( 880 lb ) at the front of the bucket.
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
1992 DFI PULL SPREADER (A57192)
1992 DFI PULL...
2012 Chevy Equinox SUV (A56859)
2012 Chevy Equinox...
LOT: (2) Piece Mac Tools TRCH 1000 Tool Box w/Contents: Lower Tool Box: 18-Drawers, Upper Tool Box (A59076)
LOT: (2) Piece Mac...
2022 Horizon (A55973)
PALLETS OF HEAVYEQUIPMENT (A58214)
PALLETS OF...
