The front of your new Rotary Cutter should be adjusted to the cut height you want. On my 48" King Kutter that is normally 1-1/2". The rear should be slightly higher, I use 2-1/2". Only the front arc of the blade cuts, the blade arc at the rear exhausts clippings.
( There are no rocks in my sandy-loam. As you have rocks, you will need to adjust higher. You do not want to mow rocks
It you have the RC at same height, front and rear, the clippings stay in the RC and mulch, which bogs down the blade rotation.
Set the tail wheel first, then refine cutting height with front adjustment.
Cutter should be level, side to side. (Adjust Lifting Rod on right side of hitch. Left side in non-adjustable.)
Use a ruler to set heights.
Scotch Broom and Himalayan Blackberries are both TOUGH. You may need to mow the first time at 3" front, 4" to 4-1/2" rear for the first pass.
Every RC is its own case. You will have to play with your Tayor-Pittsburgh some to get results you deserve.
See Post #2. You may require Zerco Limit Chains to hold up front of RC and provide fine, repeatable front adjustment. Limit chains maintain front height of RC relative to tractor rear wheels when mowing undulating or rough areas.
My Limit Chains came from Steven's Tractor in Louisiana; you should be able to find Zerco or another brand closer to Washington.
Limit chains for RCs are "an oldie but a goodie".
I trust you wear safety glasses, long pants, gloves and steel toed boots when mowing with the RC.....
http://www.stevenstractor.com/accessories/three-point-hitch/chain-limiter-kit.html
http://www.eezs.com/product.php?task=detail&Product_Id=103
http://www.tractorbynet.com/forums/...271185-kubota-b3300su-zerco-check-chains.html
