Current rimguard prices? Tube or tubeless
   / Current rimguard prices? Tube or tubeless #1
BGigHarbor
Gold Member
GIg Harbor ish
.l5460, bcs 725, 852
A dealer quoted me a price of $800 to have new l5460 tires (rear) filled with Rimguard. That sounds higher than I was expected, has it gone up that much recently?
One poster said his tubeless tires actually slipped on the rim using Rimguard. And I read that some tire places will only fill tube tires to contain the mess......
In reading posts about tube vs tubeless when filling, I like the sound of the potential ability of repairing a puncture with tubeless.
   / Current rimguard prices? Tube or tubeless #2
Mine were $500(16.9 x 28 R1 tires) if that gives you any reference. That was a year ago...
Sent from my LGL35G using TractorByNet
   / Current rimguard prices? Tube or tubeless #3
5 years ago I paid $325.00. (16.9 x 28 R1 tires)
   / Current rimguard prices? Tube or tubeless #4
I have not pulled the trigger on my Grand L but they quoted me around the same price plus another $200 for pickup/drop off at my house.
   / Current rimguard prices? Tube or tubeless #5
I had my tires slip on the rims. It was more the fact the pressure was low than the rimguard. I can't clear the rimguard from my valve stem very well and I don't want that stuff going in my tire gauge, so I just guess on the tire pressure.
   / Current rimguard prices? Tube or tubeless #6
From the inside of a tire...... It don't matter what color the tractor is....
So I did it myself to fill my tubeless R4s (22 gallon each) with anti freeze and windshield washer fluid.
The concentration I felt I needed for my cold winters the materials, valve stem adapter, and a 12V bilge pump all cost less than $90.......
I don't seem to miss the small increase in weight per gallon of other products...
In that price I also bought a "wet" style tire pressure gauge that I keep in a plastic jar of water to keep anything from gumming it up...
I take the jar in the house in winter......
Good luck
   / Current rimguard prices? Tube or tubeless #7
Wet style pressure gauge? I never heard of one. but I think I need one.
   / Current rimguard prices? Tube or tubeless #8
I can't say I've ever used a pressure gauge on a loaded tire, I've always set it where the tread is just touching all the way across...
   / Current rimguard prices? Tube or tubeless #10
I've never had a problem with the tires slipping on the rim, but I tend to run higher pressure than most.
I paid about $4 per gallon if I remember correctly. It pays to call around though, as another dealer I checked with was over $7 per gallon less than an hour away!
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
2016 JOHN DEERE 700K LGP CRAWLER DOZER (A52705)
2016 JOHN DEERE...
2019 Fontaine EQ1 Hydraulic Equalizing Spreader (A52377)
2019 Fontaine EQ1...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
2013 TALBERT TRI-AXLE DETACH TRAILER (A53843)
2013 TALBERT...
2021 CASE IH 345 (A53084)
2021 CASE IH 345...
