Powe steering loss GC2610 tlb
   / Powe steering loss GC2610 tlb #1
liberty2701
Lakes region,NH
Kioti Dk50se hst
Yesterday while picking up heavy loads with my bucket. Probably 600 lbs. I would lose my power steering. It would get very erratic. Once the load was dropped, power steering returned to normal. What would cause this? Thanks
   / Powe steering loss GC2610 tlb #2
Check your hydraulic fluid level, could possibly be the cause.
Fluid level is good. I just picked up a 400lb gun safe and it did it again. As
soon as I released the weight steering returned to normal.
You would not believe what it was. My tire pressure in the front was 16psi. Should be 23. Works perfect now. I forgot I lowered it when I cut my grass so it rides a little smoother.
   / Powe steering loss GC2610 tlb #5
Glad to hear you figured it out ........before you ruined your steer tires.
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2015 KENWORTH T660 SLEEPER TRUCK (A58214)
2015 KENWORTH T660...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A56435)
2023 Kubota...
