TODAYS SEAT TIME
   / TODAYS SEAT TIME #2,691
thanks! from creek to ridge, mine goes up 'bout 180' in a 1/4 mile
the view lookin' out the other side of those trees is really nice, once i get that mowed i'll get a pic
   / TODAYS SEAT TIME #2,692
Today I started trimming the hedges around the property. Cutting the branches with the tractor mounted hydraulic trimmer, picking them up with the grapple on the minidigger, driving them to the burning place ... Will be doing that for a number of days.
that would be slick if you made up a little hitch to bolt to the mini-ex blade a just pulled the trailer behind you as you go.
   / TODAYS SEAT TIME #2,693
decided to try n mow my slopes last night, new to farmin' n mowin' so i was a lil weary of this task... tractor felt more stable than i woulda guessed. guess seat time helps to get useds to what you can and can't do...
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=333075"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=333076"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=333077"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=333078"/>
Beautiful place!
   / TODAYS SEAT TIME #2,694
Used the tree puller on the biggest cedar tree that I have tried to pull so far. Raised the rear end when I tried to pull it straight up, so I curled down while pulling up and moving forward. That broke some roots loose.
Curled up while pulling up and moving backwards. That broke some roots on the other side.
Went forward again and it started coming up.
It came out of the ground and brought another tree with it!
Shook the dirt off of the roots and the other tree fell to the ground.
I looks to be about 3" in diameter.
2 trees, 1 pull!
   / TODAYS SEAT TIME #2,695
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=333157"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=333158"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=333159"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=333161"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=333163"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=333164"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=333165"/>
2 trees, 1 pull!
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=333166"/>
Looks like the guy with that jd1023 pulling stumps could use your services
   / TODAYS SEAT TIME #2,696
Yep, if I can't pull them, I pop them out with the stump bucket! :D
   / TODAYS SEAT TIME #2,697
X, it looks like you can get some work done with that thing. You did a number on those cedar trees.
   / TODAYS SEAT TIME #2,698
Yep, thanks. It also excels at moving dirt with the 6' wide, 1 cubic yard bucket.
   / TODAYS SEAT TIME #2,699
X, is that clay/dirt just what was there naturally? You could grow something in that dirt. I have a little clay on our river land, but up here at the house, it is nothing but sand. We grow prickly pears mostly.
   / TODAYS SEAT TIME #2,700
This part of the pond was under water when we bought this place about 2 years ago. I opened the drain valve because I need fill dirt and the center of the pond was only three feet deep due to the silt.
We also have a lot of prickly pear.
The pond from the for sale listing.
It went dry 6 months later, so I opened the drain valve to keep it that way.
In the first picture, #1 is where I am removing dirt, #2 is V417 tire tracks, where I took short cuts! :D
2024 Chevrolet Silverado Pickup Truck Bed (A49461)
2024 Chevrolet...
2016 Ver-Mac S/A Towable Trailer Message Board (A49461)
2016 Ver-Mac S/A...
2009 PETERBILT 340 (A50854)
2009 PETERBILT 340...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
Ford Super Duty Pickup Truck Bed (A49461)
Ford Super Duty...
2012 MACK GU713 DUMP TRUCK (A50459)
2012 MACK GU713...
