replacing a pitman stick on a John Deere 8w
   / replacing a pitman stick on a John Deere 8w #1
redsky47
longmont, co
kioti 3054
Took the pitman stick off of my John Deere 8W sickle mower to check for cracks and when I put it back on, I had trouble compressing the spring. Ultimately the spring expanded and broke the spring socket drilled into the end of the wooden pitman (some irony there... ), so I ordered another one. Anyone have any suggestions on the best way to re-install a pitman arm that doesn't involve wrestling, a red face and lots of sweating?
Redsky47
   / replacing a pitman stick on a John Deere 8w #2
Redsky47
The only way I've been able to compress the spring is by using the mechanical advantage built into my jd9. Bolt the flywheel end of the stick on. Clamp the brackets to the stick, I use C-clamps. with the fork and spring installed between them and the spring extended. Loosely place the fork and brackets around the mower knuckle. Clamp the cutter bar in the full retracted position and hand crank the pto shaft until the holes in the shaft line up. Quite often they won't quite lineup and I push phillips screwdrivers through two bolt holes to complete the alignment.
PALLET OF MISC BOAT MOTOR PARTS (A58374)
PALLET OF MISC...
2006 TerraGator 8104 (A56436)
2006 TerraGator...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
CARONI 6' FINISH MOWER (A52708)
CARONI 6' FINISH...
LOT OF OUTDOOR FURNITURE (A58374)
LOT OF OUTDOOR...
1998 WABASH TL Wabash National Corporation (A56858)
1998 WABASH TL...
