MF 135 Orchard..problems with 3 point Hitch not going up
   / MF 135 Orchard..problems with 3 point Hitch not going up #1
robstowing
Harrisville
MF 135 Orchard
I have a Massy Ferguson 135 Orchard Tractor the 3 point hitch won't go up.
I emptied the hydraulic fluid, took the top of the gear box cover off and replaced o rings and
seals, didn't see anything broke, piston pump is moving. Couldn't see anything wrong, cleaned the
relief valve it was okay. Still won't go up. Any ideas that would help?
Thanks Rob
   / MF 135 Orchard..problems with 3 point Hitch not going up #2
Try moving the draft arm back.
   / MF 135 Orchard..problems with 3 point Hitch not going up #4
Did you remove the pin in the linkage before you removed the top cover? If not you need to find it the bottom or it could cause major problems if it gets caught in a gear or something. I'm not an expert on why it won't lift but there is lots of info on the net and other websites.
Eager Beaver 20XPT (A47477)
Eager Beaver 20XPT...
(41) T-POSTS W/ (20) ROLLS OF BARBED WIRE (A54757)
(41) T-POSTS W/...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
2005 Ford F-150 Pickup Truck (A54814)
2005 Ford F-150...
Honda EU3000is Gasoline Companion Inverter Generators (A55851)
Honda EU3000is...
UNUSED FOLDING WAGON (A54757)
UNUSED FOLDING...
