Picked up a new to me welder Lincoln Pro Mig 140
   / Picked up a new to me welder Lincoln Pro Mig 140 #1
Whitnel
Gold Member
Lebanon, TN
Kubota GL3240
It is smaller than what I was looking for but I think I got a pretty good deal on it. Paid $300 for everything in the picture, the helmet it pretty much trash and I think I will still pick up new welding cart. He made this as his first project so it is a bit lacking. The tank still has some gas in it. :)
[URL=http://s388.photobucket.com/user/whitnel/media/Welder/P1230806.jpg.html][/URL]
Anyone know what these things are?
[URL=http://s388.photobucket.com/user/whitnel/media/Welder/P1230807.jpg.html][/URL]
[URL=http://s388.photobucket.com/user/whitnel/media/Welder/P1230809.jpg.html][/URL]
Got it cleaned up tonight, I will try it out tomorrow.
[URL=http://s388.photobucket.com/user/whitnel/media/Welder/P1230810.jpg.html][/URL]
The power cord has a bad spot on it where he must have dropped a piece of metal on it. Can I just get a replacement plug at Lowes and put that on or do yall recommend getting a whole new replacement cord?
   / Picked up a new to me welder Lincoln Pro Mig 140 #2
i would just put another plug on it.if you wish to weld some thin aluminum lincoln offers a liner, wheel and tip kit.
No plans for aluminum at the moment, just some stuff he threw in. I thought you needed a spool gun for Aluminum but he said it would push the wire as long as the gun & hose were straight.
   / Picked up a new to me welder Lincoln Pro Mig 140 #4
lincoln offers a kit with a teflon liner bigger tip and wheels made just for aluminum.it will weld.a spool gun is better but more expensive.
   / Picked up a new to me welder Lincoln Pro Mig 140 #5
Trying to feed aluminum with a standard MIG gun is like trying push string. Much better chance of it screwing up than actually working properly. $300 was a good deal including the cylinder as long as the cylinder can be filled or exchanged.
   / Picked up a new to me welder Lincoln Pro Mig 140 #6
arc weld have you ever tried it with lincolns kit? i have it works.
   / Picked up a new to me welder Lincoln Pro Mig 140 #7
I am thinking about a small 110 mig, does that have infinite voltage control?
   / Picked up a new to me welder Lincoln Pro Mig 140 #8
Those clips are for sheet metal work.
The thin blade goes through the gap between two pieces of sheetmetal, and the little bar goes through the hole in the blade. You tighten the wingnut to pull the little bar aganst the back if the sheetmetal panels, holding them edge to edge with only a small gap. Used for autobody work.
   / Picked up a new to me welder Lincoln Pro Mig 140 #9
I second the sheet metal clamps.
Handy little suckers if your trying to hold sheet metal together.
Now I see said the blind man. Makes sense now.
2014 Dodge Ram 4500 Versalift Bucket Truck (A52377)
2014 Dodge Ram...
2017 TAKEUCHI TS50V SKID STEER (A52706)
2017 TAKEUCHI...
2011John Deere 244J (A47477)
2011John Deere...
72'' power rake (A53421)
72'' power rake...
UNUSED 10PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 10PCS...
