Needing a Used Good DK 45 Crankshaft or DK 45 A4220 Engine
   / Needing a Used Good DK 45 Crankshaft or DK 45 A4220 Engine #1
dwiegand
********* Texas
DK 45 Kioti Tractor
If anyone out there has either a crank shaft or a complete engine for a Kioti DK 45 Engine model number is A4220, PLEASE give me a call or email me at dwiegand07@gmail.com. Crankshaft for. DK 40 is the same.. You can also call or text me 903 948 8611
   / Needing a Used Good DK 45 Crankshaft or DK 45 A4220 Engine #2
What'd you do?
What'd you do?
Spun a crankshaft bearing on #1 cyclinder.
Need either an engine or a good used crankshaft. Can either be out of a DK 45 or DK 40. Both engines A4200 and A4200 use the same crankshaft. 903 948 8611
   / Needing a Used Good DK 45 Crankshaft or DK 45 A4220 Engine #4
First thing is to find out if oversize bearings are offered in the 0.010", 0.020", 0.030" oversize. Take your crankshaft to a good crankshaft grinder. They will inspect the crank to be sure it is straight, and can be reground. A very good engine machine shop can usually find a bearing match also if Kioti doesn't offer oversize bearing.
2004 Ford E-350 Passenger Van (A51692)
2004 Ford E-350...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
NEW Thiessen Track Closer Disk (A57024)
NEW Thiessen Track...
1980 ATHEY AB6905 MOTOR GRADER (A52707)
1980 ATHEY AB6905...
2012 Ford Escape XLT SUV (A55853)
2012 Ford Escape...
Hercules Pesticide Applicator Tank with Nozzle (A55852)
Hercules Pesticide...
