Planning stages for remotes for stump grinder
   / Planning stages for remotes for stump grinder #1
lovedgor
Member
Etowah, Tn.
Kubota M6040
After my first post about rear remotes, I have been considering using diverter valves from the FEL Quick Connects to control the stump grinder. Does anyone think this would be a bad idea?
   / Planning stages for remotes for stump grinder #2
If your FEL valve has regen, I would bungee the valve lever to the tilt up side.
Why do you not want to use the rear remotes?
I was just thinking it would be easier and cheaper to use the valve already installed. I will use the regen to return the grinding wheel back to start position. I have one rear remote already, and will use it for top link. If I use the diverter plan, I can use it for a grapple also, and not have to install both a valve and diverter.
   / Planning stages for remotes for stump grinder #4
2008 Ford F-250 Reading Service Truck (A55788)
2008 Ford F-250...
2022 JCB 3TS-8T Teleskid Loader with Telescopic Boom, DB84 Dirt Bucket and FAE Forestry Mulcher (A55218)
2022 JCB 3TS-8T...
201907 (A54756)
201907 (A54756)
2007 JLG SKYPOWER 800AJ TELESCOPIC MANLIFT (A52705)
2007 JLG SKYPOWER...
Hose Reel (A55758)
Hose Reel (A55758)
John Deere MX6 Rotary Brush Cutter Tractor Attachment (A55787)
John Deere MX6...
