New Plow for the new B "50" series
   / New Plow for the new B "50" series #11
I saw a 6 foot plow on what looks like SSQQ on the B 50 series?
Does anybody have a price or knows who makes it?
If it really is a true SSQA it will fit my L3200.
Thanks,
Roaf3
The new Kubota Bxx50 tractors have an option to put an SSQA adapter on the FEL. I bought one a few months back - as soon as they were available - and installed it on the LA504 FEL on my B3200. I also got a 54" and a 60" Kubota bucket - and a Virnig rock bucket to go on the tractor. The Virnig rock bucket is "standard skid steer attachment" - and fits right onto the Kubota SSQA adapter. I also recently picked up a fork frame from Artillian - that was built using a standard SSQA adapter - and that also fits onto the Kubota SSQA adapter without any issues.
I've also done the measurements - and can tell you the Kubota stuff meets the SSQA standard.
So long story short - the snow blade should be standard SSQA and fit right on your tractor if it's also standard.
   / New Plow for the new B "50" series #12
I have a question. On the new Kubota B2650/B3350 they offer a skid steer quick attach as an option. I read some where that a standard skid steer attachment would not fit, that the quick attach for the B series would only fit Kubota attachments. Does anyone know if this is true?
   / New Plow for the new B "50" series #13
What you read was wrong.
I bought one of the Kubota skid steer QA's from the new Bxx50 tractors back in May as soon as they hit the dealer supply pipeline and installed it on the LA504 loader on my B3200. Along with the SSQA I got the 54" and the 60" Kubota buckets - and I bought a Virnig 54" rock bucket. The Virnig rock bucket is made to standard SSQA specs - and it fits perfectly on the Kubota SSQA. I also Artillian make a fork frame for the tractor. When he made the fork frame he used a standard off the shelf SSQA plate - and that also fits on the Kubota SSQA just fine.
So - long story short - the Kubota SSQA from the Bxx50 tractors fits standard skid steer attachments with no problems whatsoever - that I have found.
The thing you need to be careful of though - is finding skid-steer attachments that don't weigh a ton. The lift capacity of the LA504 is in the 900-1000 pound range - so using skid steer attachments that are made to lift 2000-2500 pounds is gross overkill and is going to eat up a lot of the lift capacity of the loader (because they will weigh in very heavy)
   / New Plow for the new B "50" series #14
Thanks jim_wilson, I should of ascertained the answer from your previous post but did not read it close enough. Thinking on my question, I believe what I read was about the BX series quick attach.
You are correct about attachment weight robbing the lift rating. On my L4610, somewhere around 50lbs is the difference between lifting and not.
1993 Barrett Gooseneck Livestock Trailer (A50514)
1993 Barrett...
2019 Nissan Sentra (A50324)
2019 Nissan Sentra...
2015 CATERPILLAR 305E2 CR EXCAVATOR (A51242)
2015 CATERPILLAR...
LANDPRIDE RCR1242 - 4' ROTARY MOWER (A51243)
LANDPRIDE RCR1242...
TAYLOR TDF-60S STRAIGHT MAST FORKLIFT (A51242)
TAYLOR TDF-60S...
John Deere 6410 Loader Tractor (A50514)
John Deere 6410...
