question about hydraulic rear bladeswith 3 rear remotes
   / question about hydraulic rear bladeswith 3 rear remotes #1
BGigHarbor
Gold Member
GIg Harbor ish
.l5460, bcs 725, 852
Say a person had a tractor with topntilt and 3 rear remotes.
Say they were considering buying a LP RBT3584 which is a rear angle blade that can have manual or hydraulic angle, tilt, or offset.
Seems likely the hydraulic angle is a no brainer.
How best to put the other two remotes to work? Offset seems it would be handy but it would take away top or tilt.
And is tilt done best on the blade or through the 3pt tilt?
Crimenies, is this a case for 4 rear remotes?
All hypothetical of course.
   / question about hydraulic rear bladeswith 3 rear remotes #2
Yes 4 remotes, "T&T", offset and angle on the blade. Just get the ratchet for tilting the blade. You want the tilt on the hitch so that you have that capacity for your other implements. Very very seldom do you need to tilt more that what the hitch will do, and if you do, then you manually tilt with the ratchet on the rear blade and fine tune that tilt with the 3pt hitch tilt.
I just finished a remote setup for a guy that has an M7040. He needed 6 total rear remotes for his tractor. Not only did he get my "T&T" set, but with his Land Pride blade he got all 3 functions hydraulically operated along with hydraulic operated gauge wheels. So he used 2 OEM valves for the "T&T" and the 3rd unit goes through a 3 diverter valve bank to end up with the 4 sets of outlets that he needs to operate his rear blade. :cool:
   / question about hydraulic rear bladeswith 3 rear remotes #3
Brian, can you tell us a little about that 3 diverter valve bank?
-Jim
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
UNUSED AGT AIR COMPRESSOR W/ 420CC MOTOR (A51248)
UNUSED AGT AIR...
2008 Chevrolet Uplander LS Van (A51694)
2008 Chevrolet...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
1271 (A50490)
1271 (A50490)
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
