Dont laugh at me too hard !
   / Dont laugh at me too hard ! #1
dclynch
kawkawlin,mi
Rhino International
I have a tractor that has two levers next to the hydaraulic lever that is used for raising and lowering the 3pt. Would these work for a TNT? there are a total of 4 ports 2 on each. Are these called rear remotes? As you can see I am not a tractor expert just use it for brush hogging planting a garden and food plots, and plowing snow it sits in the garage most of the year.
   / Dont laugh at me too hard ! #3
Seems you have two Remotes and yes they would work on a TnT set-up. TnT Is a Hydraulic Top link and a Hydraulic Box Leveler.
   / Dont laugh at me too hard ! #4
Don't laugh at me, but what is a TNT?
Top N Tilt.. in other words. hydraulic cylinders replacing the "Top" link, and a hydraulic cylinder replacing the side tilt lifting link, usually on the right side of the tractor. So you are replacing mechanical jack-screws with hydraulic cylinders. So now you can make adjustments to an implement on the fly from your seat instead of getting off of the tractor to adjust the toplink length or the side like to adjust the tilt of an implement.
James K0UA
Thanks for the quick replies, I definitely will be lookin into getting a TNT.
   / Dont laugh at me too hard ! #6
it all depends on the tractor you have one could be a draft control
   / Dont laugh at me too hard ! #9
How about a photo of the back of your tractor showing the remotes? That would help to clarify the issue.
   / Dont laugh at me too hard ! #10
I dont think I've ever heard anyone complain about having TnT. ;-)
Wedge
2015 TROXEL 130BBL KILL TRAILER (A53843)
2015 TROXEL 130BBL...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2017 CATERPILLAR D11T DOZER (A52705)
2017 CATERPILLAR...
PAIR OF 10 TON AIR LIFT JACKS (A53843)
PAIR OF 10 TON AIR...
MAJOR LOT NUMBER 260 (A53084)
MAJOR LOT NUMBER...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
