Mowing What size bush hog is best suited for use on a BX23?
   / What size bush hog is best suited for use on a BX23? #1
davcog
West Gardiner, Maine
Kubota BX 23
I'm the trail master for the local snowmobile club and we currently use a walk behind bush hog. As a lot of our members are getting a little long in the tooth we are thinking of upgrading to a tractor mounted bush hog. No more wrestling with the walk behind.:scratchchin:
   / What size bush hog is best suited for use on a BX23? #2
42 or 48.
Bruce
   / What size bush hog is best suited for use on a BX23? #3
Yep, I think the manual recommends a 42", I use a 48" Land Pride on ours.
You really need to get some sort of HST fan protector from Bxpanded, Bro-Tek or fabricate one, I also have a steering linkage guard as the BX doesn't have much ground clearance and I have torn boots on mine in the brush.
   / What size bush hog is best suited for use on a BX23? #4
48 max. smaller is better for thick heavy stuff, but if you currently use a walk behind- there is no point in getting smaller then 48.
   / What size bush hog is best suited for use on a BX23? #6
The Land Pride RCR15 Series and Woods makes an RCC42 for the small tractors.
   / What size bush hog is best suited for use on a BX23? #7
The Woods 42" is a great choice for that tractor.
Will
Thank you all for the responses and recommendations.
Next project is fan protector. Replaced one but needs another now. Dou you have pictures of all your guards? Hate that you have to buy the whole tie rod assembly to replace the boots.
   / What size bush hog is best suited for use on a BX23? #10
Sorry, my my son didn't take any pictures prior to or after installation, but here are some links and a picture of the boot protectors:
Skidplate - BXTractors.info: The Kubota BX Wiki
Bro Tek plates - Bing Images
I also replaced the turnbuckles with adjustable bars from Stabilworks.
2003 Ford F-650 Flatbed Truck, VIN # 3FDNW65243MB03484 (A48836)
2003 Ford F-650...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
HEADACHE RACK (A50854)
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2011 Liebherr L586 (A51039)
2011 Liebherr L586...
2014 FORD F-350 SUPER DUTY CREW CAB FLATBED TRUCK (A51243)
2014 FORD F-350...
