How many implements/ attachments do you own?
   / How many implements/ attachments do you own? #41
Okay I'm guilty of not counting my FEL so add 1 to your stats. I highly suspect your average is is heavily skewed high due to most folks with only a few attachments aren't chiming in. It's a condition I am coming down with... "Implement Envy".
So you are thinking that some of us guys with somewhat "less" than the average 11.2 implements, might just be coming up "short"?:D and keeping quiet about it?
Now 25 people posted for a total of 278. The average is 11.12.
I don't think this is very accurate because most of us on TBN probably have way more implements than the average tractor owner.
   / How many implements/ attachments do you own? #43
Yep... I was worried about pushing the reply button with 3. Now 4 counting my FEL. :ashamed: Note that very few have chimed in that are 'short' in that department :D
FEL, Bucket, SSQA pallet forks, SSQA grapple, SSQA Snow plow, 2 quick hitches, 2 draw bars, MMM, 5' scraper blade, 7' scraper blade, 3Ph pallet mover, middle buster, 6' box blade, 6' landscape rake, pond scoop, 4' core aerator, 1 row cultivator, 5' rotary cutter - 20
   / How many implements/ attachments do you own? #45
You might have an addiction.
Nah those guys with 30 or more do:)
I am hoping it will be 21 soon. I need to get a piece of metal to finish my trailer mover.
   / How many implements/ attachments do you own? #47
Why would you think anyone is
short" in the number of implements?
We're not all farmers and I reckon a good percentage of TBNers don't need many implements...I don't.
   / How many implements/ attachments do you own? #48
Why would you think anyone is "short" in the number of implements?
   / How many implements/ attachments do you own? #49
Flexi coil 35ft air seeder
Flexicoil 40ft chisel plow
Friggstad 36ft chisel plow
Morris 32ft chisel plow
25ft white chisel plow
10ft pt chisel plow
70ft summers superharrow
70ft diamond harrows
70ft tine harrows
36ft allis tandem disks
8 row JD 7000 corn planter
Case IH 25ft swather
Case IH 3x3 square baler
NH 650 round baler
30ft tandem axle semi trailer on converter
NH 495 haybine ...X2...
8 Yard Miskin scraper
950 gal hardi high clearance sprayer
Case IH row crop cultivators (8 row)....X2
V rake
basket rake
3pt snow blower ...X2
25ft flail stalk mower
finnish mower
11ft woods heavy mower
6 ton dump grain trailers ....X2
hyd rear angle blade
Home made pull type 14ft root rake
5 ton trailed fertilizer spreader
1 ton 3pt fertilizer spreader
box blade
3pt rear bulldoer blade
10x70grain auger
mf 8 furrow plough
3pt rear triplex mast forklift
20ft tandem axle hay trailer
REM grain vac
there are more but can't think of them right now
   / How many implements/ attachments do you own? #50
15 counting the bucket and forks
   / How many implements/ attachments do you own? #51
6 ft and 7 ft mower, box blade. root grubber, grading blade, rake , grapple, hay grapple, spring tooth cultivator, 60 gallon sprayer, spreader, chain harrow with frame, front and rear hay forks. pasture aerator, fel, post hole auger, 6 ft disk, cultipacker, rachet rake, hay rake, disk mower, 3 point trailer mover.
   / How many implements/ attachments do you own? #52
72" QA loader / back blade / landscape rake / box blade / KK 3pt trailer mover / 42" QA pallet forks / 64" rear snow blower / 72" QA FEL snow plow
8 counting the FEL. Not a large amount, but I'm sure the list will grow. Shhh, don't tell the wife. ;)
   / How many implements/ attachments do you own? #53
Not many: bush hog, rear blade, sub-soiler, backhoe, 2 bale spears, pallet forks... does the loader bucket count? :eek:
I'll count the Loader and the Bucket.
Now 31 people have posted for a total of 393. The average is 12.68.
   / How many implements/ attachments do you own? #55
10ft pt chisel plow
70ft tine harrows
NH 650 round baler
V rake
basket rake
finnish mower
box blade
10x70grain auger
mf 8 furrow plough
REM grain vac
There were 9 combine headers 3 flex , 2 x 8 row corn , 1 sunflower , 2 pickup and a straight cut but sold one today :)
   / How many implements/ attachments do you own? #56
I guess ill throw in here. i help my granddad around the farm. so ill list his equipment that i also use there some i own to
John Deere 7000 planter
oliver 516 plow (bought brand new only used 3 or 4 times)
batwing disk
woods industrial road side mower
stalk shreder
copper cliper 3 pt shreder
bat wing harrow
pull type fertilizer spreader
sprayer
kinze auger wagon
brent auger wagon
buffalo culivator
jd culivator
and other random pieces
dirt work we do with either the
2013 john deere 5065E and loader
or 1950s cat d6 9u BUlldozer
HD5 allis chalmers Bulldozer (my personal favorite)
Cat 12E motor grader with 14 ft blade, sacrifier, and mounts for v plow and wing plow,
skid loader attachments
brush graple
9ft reach back hoe
post hole digger
tree shear
bucket
pallet fork
and a lull 40 foot telahandler
im not going to go into tractors cause there is 40 + of those
   / How many implements/ attachments do you own? #57
I think all mine are listed in my signature. I'd love to add either a logging winch or skidding grapple, a pull behind snowblower, and a Turbo Saw, but KTM just got the last of my toy budget for a while :)
   / How many implements/ attachments do you own? #58
Whoa !! We have to a list of those. Please. That must be a TBN record or near TBN record.
   / How many implements/ attachments do you own? #59
OK
we will start with the john deere's
a
b
40
50
60
70
720
430
530
630
730
830
4320
5065E
Oliver
77
88
770
1800
1950
2255
minneapolis moline
UTU
Case:
vac
vac
930
Farmall
a
c
h
m
Massey Harris
44
allis chalmers
wc
c
wd
wd45
hd5
D15
D17
cat
d6
12E
cletrac
we have one it is a ? as to what it is
Jacobsen
g10
g10
that is the current list it is subject to change at my grandpas wim
   / How many implements/ attachments do you own? #60
1998 INTERNATIONAL 9100 WATER TRUCK (INOPERABLE) (A55745)
1998 INTERNATIONAL...
2012 Chevrolet Camaro Coupe (A59231)
2012 Chevrolet...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
2012 HYUNDAI  HL740-9 WHEEL LOADER (A58214)
2012 HYUNDAI...
YANMAR VIO35-6A EXCAVATOR (A59823)
YANMAR VIO35-6A...
