GManBart
Elite Member
- Joined
- Dec 10, 2012
- Messages
- 4,976
- Location
- Detroit, Michigan
- Tractor
- Massey Ferguson 241, Kubota SVL90-2
Got the LS,
21k with the Tires juiced. Have about ten hours on it mostly mowing. 3 point stabilizer arms bent up when the pin came out. Bent them back and put a locking pin in there no problem. Dealer is giving me new arms as it is. The 3 point hydraulic speed control spun out as the lock nut must have been loose and shot about 5 gallons of hydraulic oil out. The dealer sent a guy out with oil and a new o-ring on a Friday afternoon before the 3 day weekend. The head and dash lights went out the other day. It's not the fuse. Dealer is sending a guy out.
When the hydraulic oil spewed out and I was waiting on the repair a used JD 4120 came up on craiglist with 190 hours a back blade and a 6 ft brush hog for the same price I paid for the LS. The loader cycles faster than I thought it would. Lifting a bunch of railroad ties lifted the back tires off the ground I will have to try that again with the hog on the back.
Got the 42" quick attach forks from palletforks.com with the 60" extensions. Really like the forks. Jury is still out on the extensions.
Only time will tell if I made the right move on the LS. The commercial nursery next door swears by the brand and the dealer. It will work fine for now. I hope it lasts years and the company grows and is around for a long time. We will be buying smaller tractor in about 5 years to get up and down the narrow rows to spray etc. Hopefully I can buy an LS with confidence.
That's the first I've heard about issues with the lights, or 3pt lockout, but I definitely don't like the style pin they use on the 3pt stabilizer bars....I just put graded bolts in mine.
Loaded tires help, but that really isn't what you need for doing serious loader work, and all but the heaviest brush hogs are too light. I run a 1300lb counterweight, and I can finally max the loader without lifting the rear tires. 500-600lbs on the 3pt was nowhere near enough. For comparison, Kioti specs a bit of 1000lbs on the 3pt for their similar (slightly higher lift weight).
Even if loading the rear tires would keep them on the ground while doing loader work, you would still be (or coukd be) overloading the front axle. Only 3pt weight can fix that....makes the rear tires a fulcrum point, like a teeter-toter, and takes weight off the front axle.
Good luck with it!
