Cleaning out a culvert?
   / Cleaning out a culvert? #21
Bruce,
Those links you put up were fascinating.
   / Cleaning out a culvert? #22
If yiu redo the culvert I would use at a bare minimum 15" (11" x17") but prefer 18" or equal (14" x 22" ERCP). A 12" pipe is simply too easily plugged by fairly small materials. Although I don't know for a fact, I hear RCP (reinforced concrete pipe) is nearly as cheap as ACCMP (asphalt coated corrugated metal pipe).
   / Cleaning out a culvert? #23
With the ledge problem he described he probably would want something with an open bottom. If it's just cross drainage instead of a regular stream than he may be OK.
2018 CATERPILLAR 259D SKID STEER (A52705)
2018 CATERPILLAR...
UNUSED TELESCOPIC LADDER - 3.2M (A54757)
UNUSED TELESCOPIC...
2005 OSHKOSH FRONT DISCHARGE CONCRETE TRUCK (A54313)
2005 OSHKOSH FRONT...
UNUSED LANDHERO LDH-GAC40Y AIR COMPRESSOR (A54757)
UNUSED LANDHERO...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2008 New Holland L175 (A47477)
2008 New Holland...
