best post hole digger for less than $1000
   / best post hole digger for less than $1000 #11
I have often thought about making one out of an old rear end. If done right, probably better than anything the market. You dont see too many PHD's with gearboxes than can handle 200+ HP. (of course not that you would be using one with a 200HP tractor...):laughing:
   / best post hole digger for less than $1000 #12
You might be able to use one from an independent rear end or independent 4x4 front end and not have to shorten axle housings.
Bruce
   / best post hole digger for less than $1000 #13
I just scanned craigslist where I live and there was about ten 3pt post hole diggers, only one of which was over $1000
   / best post hole digger for less than $1000 #14
   / best post hole digger for less than $1000 #15
Our new EA Post hole diggers are well under $1000. They ship free to your home within 1,000 miles of Newton, NC.
The 7500 HD for Category 2 tractors will not UPS, so it ships free to a business or supporting freight terminal within 1,000 miles.
The best size for a 3520 would be the 6900 or the 6900HD(larger gearbox).
I hope this helps.
Travis
   / best post hole digger for less than $1000 #16
Most people don't wear their post hole diggers out, in fact they often get little use. If you can find one that has been stored under cover, save some money and buy used.
   / best post hole digger for less than $1000 #17
Welcome to TractorByNet!
I moved your thread to the Attachments forum. :)
   / best post hole digger for less than $1000 #18
IMHO Unless you will use a post hole digger a lot there is little value in buying a high end unit. Look for a lightly worked used one with a gearbox HP rated close to your tractor. In other words you won't need a 100 HP gearbox for a 50 HP (PTO HP) tractor, unless you can get a really good deal. Conversely don't buy one with a gearbox rated for way less than your PTO HP.
My two cents worth.
Rick
   / best post hole digger for less than $1000 #19
My two cents worth.
Rick
I agree with this. When you need them you need them. So you use the heck out of them when installing a fence. Other than that, they gather dust waiting for a fence post to rot off and fall over. That can be a lot of waiting time.
   / best post hole digger for less than $1000 #20
I made my own PHD for under 1K. I think I was at 850 or so with hoses. Steel was pre-cut and pre drilled, did my own welding (not much needed)
2018 Ford F-250 Reading Enclosed Service Truck (A53422)
2018 Ford F-250...
2014 Dodge Charger Sedan (A52377)
2014 Dodge Charger...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2008 ATOKA TRAILER & MFG. ATOKA TRAILER & MFG. (A53843)
2008 ATOKA TRAILER...
2003 Ford F-350 King Ranch 4WD Pickup Truck (A53117)
2003 Ford F-350...
2013 Chevrolet Silverado 1500 4x4 Ext. Cab Pickup Truck (A52377)
2013 Chevrolet...
