OIL PRESSURE ON YANG DONG 385
   / OIL PRESSURE ON YANG DONG 385 #1
DUMMASS
Member
PHELAN ,CALIFORNIA
NORTRAC NT-204C /Jinma Y380 engine
Who knows the correct oil pressure for the Y D 380 engine? manual says 50 - 60 psi that seems high .. :confused::confused3::confused2::D
OIL PRESSURE ON YANG DONG 380
   / OIL PRESSURE ON YANG DONG 385 #3
Seems ok to me for a cold engine. Even better for a warm engine.
Thanks Bob, just thought it might "wash out" main bearings thanks again...
Phil
   / OIL PRESSURE ON YANG DONG 385 #5
Well, you may have misinterpreted the manual. What it says is 0.2 to 0.4 MPa, which - when converted from metric - is 29 to 58 psi. They're trying to tell you that (up to) 58 is ok right after starting a cold engine, and that it should run at least 29 once warmed up to operating temperature. Further, pressure as low as 7 psi at idle (900 rpm) is acceptable. I've had 4 Chinese tractors, and they all ran consistent with similar numbers spec'd in their respective engine manuals.
//greg//
   / OIL PRESSURE ON YANG DONG 385 #6
I have a Jinma with a similar engine. I see 55 at startup then about 25 after good and warm. I see about 10 when warm at low idle.
Chris
   / OIL PRESSURE ON YANG DONG 385 #7
Cold temps and cold engine mine can run upwards of 80PSI, has since new with a direct reading gauge. Warm it can drop back into 20 psi at lower RPM. and have seen it HOT down around 10 idling to cool down.
there is a pretty big post here that has pics of mine in it.
here is OP at 1400RPM at 180F
click the thumbnail pic for larger view.
and idling hot temp.
Mark
THANKS GUYS NOW I'VE GOT BIGGER PROBLEMS......................................
   / OIL PRESSURE ON YANG DONG 385 #9
Phil
really?
my old fords with red tigers in good condition run that high.. and they are gassers from 1953-1964
50-60 psi startup cold is 'bragging rights' type oil pressure...
2017 GENIE GS-1930 ELECTRIC SCISSOR LIFT (A53843)
2017 GENIE GS-1930...
2013 FREIGHTLINER BUSINESS CLASS M2 VACUUM TRUCK (A51406)
2013 FREIGHTLINER...
2001 CATERPILLAR 140H VHP MOTORGRADER (A51406)
2001 CATERPILLAR...
2018 MACK CHU613 DAYCAB WINCH TRUCK (A53843)
2018 MACK CHU613...
2015 Ford Fusion S Sedan (A51694)
2015 Ford Fusion S...
