Beware of the Rock wrench
   / Beware of the Rock wrench #1
timster2
North East PA
Kubota BX2230 & B2320
A few days ago I bottomed out on a rock with the rear end of the BX. Nothing new rocked back and forth and passed over the rock. Took a look under the rear end no damage no problem. Well three days later I am scraping the ground clear of weeds and debris to park some skids of wood to age and I notice some liquid on the ground, figured it was water from some tarps I had just moved. Well next thing I know the bucket wouldn't raise :confused2: I notice there is a lot more water on the ground than before. I take a look under the tractor and there is oil pouring out from under the rear end. Quickly I get the tractor back to the garage, leaving a line of tractor blood in my wake, and put a bucket under the leak. I jack up the rear pull the tire, thinking I'm in for some big repair bill. I take a look and low and behold the drain plug is gone!:confused3:
Seems when I hung up on the rock the drain plug loosened and it took three days of running for it to finally fall out. Took out my metal detector and a trusty Harbor Freight magnet on a stick and start searching the dirt piles for the drain plug. Well after about fifteen minutes, success!:cool2: Well it was just about time for the 300 hour service anyway so off to the dealer for a set of filters and some hydraulic oil.
   / Beware of the Rock wrench #2
Man you a Lucky Dude!
   / Beware of the Rock wrench #3
Great story Mate!
What kind of metal detector did you use? The 'security' type that you'd use for finding nails in recycled timber or the 'treasure hunting' type?
I may need to get one for the shop! :thumbsup:
The metal detector was a 'bounty hunter' treasure hunting type. I've used it more than once to find lost hardware.
   / Beware of the Rock wrench #5
Love the metal detector idea! I lost a big chain a while back and should have thought of that. Lucky it was just a plug.
   / Beware of the Rock wrench #6
Having the proper equipment at the proper time:... Priceless! Even then the chances of finding that plug seem fairly slim.
   / Beware of the Rock wrench #7
Sometimes good things happen. Recently I started up my Kubota that was parked in the garage. The three point would not lift. The shifter handle was just flopping around loose. Turns out that a roll pin had fallen out right there under the tractor while it was parked in the garage.....didn't even need a metal detector to find it. But losing hydraulic fluid, that was a close call for you timster2.
   / Beware of the Rock wrench #8
I lost a big chain around 30 years ago and I still hope it'll turn up.
   / Beware of the Rock wrench #9
Sometimes you can find them either with a rotary cutter or a mulcher. :D
2021 Kubota SVL75-2 Track Loader (A55315)
2021 Kubota...
8ft Flatbed Truck Body with Axle (A55851)
8ft Flatbed Truck...
2025 GIYI GY-ZWB Hydraulic Backhoe Arm with Tooth Bucket Mini Skid Steer Attachment (A56857)
2025 GIYI GY-ZWB...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2008 Ford E-350 Altec AT200AV 30ft Bucket Van (A56858)
2008 Ford E-350...
