Ford 4000 kicking out PTO
   / Ford 4000 kicking out PTO #1
Old Virginia Joe
SE Va.
'63 Ford 4000, '48 Massey Harris 30
Has anyone had any experience with a Ford 4000 1963 kicking out of the PTO when mowing or other uses? Mine has kicked out of gear several times, when under a load. Mostly it does it if I am bush hogging some significant saplings, or the blade slices through a hump of dirt. Is it supposed to do this to save the transmission or clutch or shear bolt, or not? I could bungy cord it in place, but that may not be smart. The PTO is nice and tight in the rear end, no slop or looseness at all. Just wondering about this. I'm going along fine, and all of a sudden the blade is not turning, and I see under the seat the PTO lever has moved forward, out of gear. Thanks for your opinions.
   / Ford 4000 kicking out PTO #2
You have a problem within the detent assembly for the PTO shift lever, or a twist in the PTO shaft's front splines.
   / Ford 4000 kicking out PTO #3
There is a fork at the end of the shifter rod that has a nut on it that sometime works loose. The shifter rail itself could have a worn groove or a flat spot on the ball or weak spring. Or it couple be something in the assembly as stated.
Kirk
OK, thanks. Having said those possibilties, until I can look into fixing it formally, would I be OK to rig a "tie-back" hook to keep it engaged, or would that cause any damage?
   / Ford 4000 kicking out PTO #5
ditto what Rick sid.
if there is no thrust play at the shaft ( bearing / carrier damage ).. then check that detent and shifter mech..
any damage to the shaft stub itself you can see?
The end of the PTO shaft looks completely normal to me.
KMC 3376 LOT NUMBER 255 (A53084)
KMC 3376 LOT...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
EXCAVATOR ATTACHMENT (A52472)
EXCAVATOR...
John Deere S780 Combine (A53342)
John Deere S780...
2012 Chevrolet Silverado 1500 LTZ Crew Cab Pickup Truck (A51692)
2012 Chevrolet...
