Parts manual for TS 254 or comparable.
   / Parts manual for TS 254 or comparable. #1
Desert Bred
Goodyear AZ
1998 CKC TS 254 (Fei Dong 295T1)
Anyone have any in a pdf form .. i'm trying to get some parts for my chinese tractor. thanks
found one for a 2004 and it looks very comparable: frontpage.jpg
Now that I have one maybe someone could answer some basic questions..
Oil inflow:
#1 sitting on the tractor, is this located on the right side of the seat.
#2 is the filter the last or first to get oil from sump
Letter 'E':
What exactly are they referring to as 'Main control valve or Return valve'?
   / Parts manual for TS 254 or comparable. #3
found one for a 2004 and it looks very comparable:<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=337634"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=337635"/>
Oil inflow:
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=337636"/>
Letter 'E':
My guess is it controls the 3 point and typically is on the right side.
It looks like a typical Chinese hydro system. Where there is a strainer prior to the pump. When its prior to a pump its refered to as a strainer. On my Jinma its set up like this. Reservoir, strainer, pump, systems (FEL 3 point steering), then back to the reservoir.
Chris
Thanks Chris!
   / Parts manual for TS 254 or comparable. #5
I believe Chris is correct, but he may not realize that you have a PTO pump. I thought you'd have figured that out when I asked earlier if you'd visually followed the lift lever linkage. Makes sense that they'd call it a main control valve. And yes, it's logically on the same side as the lift lever. The return valve is the one sticking out beneath the front side of the seat; the one that's missing its knob.
//greg//
alright just keep in mind that terminology isn't easy to discern on day3 of tractor ownership without proper manuals.. still waiting on them.. and never having taken apart an engine or the like.. so when you say following the 'lift lever linkage'.. i read 'Make sure the linkages on both lift levers actually move with their levers.' - - - that could really only be accomplished by removing the cover on the sump i understand.
   / Parts manual for TS 254 or comparable. #7
You may end up doing that. But all external hardware/functions/controls should be confirmed as functioning first.
//greg//
Quick Attach Stump Grinder (A50514)
Quick Attach Stump...
2021 Dodge Durango GT AWD SUV (A50324)
2021 Dodge Durango...
Land Honor Quick Attach Land Plane (A50514)
Land Honor Quick...
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
2007 FREIGHTLINER COLUMBIA SLEEPER (A51222)
2007 FREIGHTLINER...
2016 Sooner STC 9042 LQ Tri-Axle Horse Trailer (A49461)
2016 Sooner STC...
