Cleaning Sludge from the Sump with??
   / Cleaning Sludge from the Sump with?? #1
Desert Bred
Goodyear AZ
1998 CKC TS 254 (Fei Dong 295T1)
Any advice on how to clean the sludge?
   / Cleaning Sludge from the Sump with?? #2
You looking for a textbook type solution? Or just something 'quick and easy' for 'likely good enough'?
'likely good enough' would suffice for now. like use 'x' solvent, not 'y'.
   / Cleaning Sludge from the Sump with?? #4
I think you're safe to use about any of the various typical solvents (I don't wanna start a list that might upset the safety police), you just want to be sure it's all out before reassembly. I like using brake cleaner to hose such things out as a final clean before blowing them out with an air compressor and reassembling.
ok. is paint thinner ok then?;)
   / Cleaning Sludge from the Sump with?? #6
I'd probably try and stick with something a bit less combustible like kero or diesel, but honestly I'd say whatever works, the key is getting it all out.
ok thats do-able. thanks for the help... i need it.
   / Cleaning Sludge from the Sump with?? #8
Is that sump part of your tractor? If so, I'd go to my local auto parts store and get a container of whatever they sell for parts washing tanks. This is what is best for this type of work. This is what I used when I had my own foreign auto repair shop.
yes thats the sump under the seat.
thats exactly what im going to do.. thx
   / Cleaning Sludge from the Sump with?? #10
Is this a hydro transmission, or a gear transmission? The magic fluid on old Fords was a mix of ATF and Diesel or Kerosene run for 5-15 mins (just driving around a little) then drain.
Aaron Z
2021 CATERPILLAR 299D3 SKID STEER (A51242)
2021 CATERPILLAR...
Case 1150G Crawler Tractor Dozer (A50322)
Case 1150G Crawler...
SpotWeld RockerRite 480V Arm Type Spot Welder (A50322)
SpotWeld...
2014 PETERSON 4700B HORIZONTAL GRINDER (A51242)
2014 PETERSON...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
