can a l5740 fit in anormal garage-
   / can a l5740 fit in anormal garage- #11
Should fit through an 8'door, though you better make sure the door is REALLY all the way up. If it is a manual lift door, you need to be sure it is all the way up and STAYS there. The cab model is just slightly shorter than the ROPS model by an inch or so. Both will still fit through an 8' door. Don't know why the previous poster said 10' door as that will surely fit, but is no where near required. Pretty sure the good people at Kubota wanted to make it fit an 8' door.... From looking at the spec sheets, they list dimensions with R1 tires as the assumed tire. Everything else is a titch lower, IME.
   / can a l5740 fit in anormal garage- #12
   / can a l5740 fit in anormal garage- #13
Ten foot door required for mine as well so no tractor in garage at house. When cleaning snow have to be careful of deck/porch as well
   / can a l5740 fit in anormal garage- #14
Correction - 9 foot door to keep ROPs up. Height with ROPs up is 101 inches. Sorry for the confusion. I shouldn't trust my memory! Haha. Here's a link to the spec sheet from Kubota:
http://www.kubota.com/product/L40/pdf/gl40_spec.pdf
That is the same height required of my P7010 LS with cab. If one could get a 9 foot door, it would fit with about 6" of spare clearance, but that would require minimum of a 10 foot ceiling to install it (do they make 9 foot doors?)
EZ-GO Freedom SE Electric Golf Cart (A57149)
EZ-GO Freedom SE...
31 FT x 50 FT Heavy Duty Metal Storage Garage (New/Unused) (A59225)
31 FT x 50 FT...
Landoll Lowboy Trailer (A56438)
Landoll Lowboy...
LOT: (6) Grease Guns (A59076)
LOT: (6) Grease...
2020 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A59575)
2020 FREIGHTLINER...
Giyi Excavator Pallet Forks (A57149)
Giyi Excavator...
