Oil & Fuel NAPA Premium Heavy Duty Traactor Hydraulic and Transmission Fluid Specs
   / NAPA Premium Heavy Duty Traactor Hydraulic and Transmission Fluid Specs #1
rider7767
Paris, TN
TYM T264 with loader and implements
Many of us have struggled with finding a suitable hydraulic oil for our Kioti's in local markets. I have used NAPA Premium Heavy Duty Tractor Hydraulic and Transmission Fluid for a few years in my old tractor and now in my new Kioti. It is not the cheapest, but it is reasonable plus you know what you are getting. The mulit grade hydraulic fluid specified in my owner's manual are hard to find. I found the tech line for NAPA's hydraulic oil. After calling, these are the oil specs. I also put the tech line info below. Note: this is for U.S. markets.
Part number "NHF 85405" five gallon bucket
Grade 10W-20
cSt at 40ーC (104ーF) 58.00
cSt at 100ーC (212ーF) 9.43
Pour Point (ーC):by ASTM D 97 -32
API Gravity 31.3
Boiling Point: Not determined. Expected to be > 260ーC (500ーF).
Specific Gravity @ 15.6oC 0.8692
Density @ 15.6oC 7.237
View attachment Lubricants-Chart-2012-07-20.pdf
Cross Oil
Customer Service Representatives: Tina Estridge & Terry Jones
Direct: 800-343-6361
Fax: 870-864-8661
Cross Oil - Contact Us
Thank you Terry at Cross Oil for the info. I hope this helps the KIOTI community. :salute:
   / NAPA Premium Heavy Duty Traactor Hydraulic and Transmission Fluid Specs #2
TSC Traveller Universal Tractor Trans/Hydraulic Fluid
Traveller Premium Universal Tractor Trans/Hydraulic Fluid is a specially formulated, premium multigrade (SAE 10W-20) fluid
Additive Type - Premium
Flash Point - 435 deg. F
ISO Viscosity Grade - Multi-Viscosity
Pour Point - -44 deg. F
Size - 5 gal.
Viscosity (SUS @ 100 F) - 400
Brand - Traveller
Mirrors the NAPA
Flash Point - is same as boiling point
Size - 5 gal.
Brand - Traveller
Mirrors the NAPA
Both will fit the bill; however, NAPA has over 6000 locations, to TSC's 1200+. People should be able to get one of the oils.
   / NAPA Premium Heavy Duty Traactor Hydraulic and Transmission Fluid Specs #4
TSC will ship $4.99 to your door, don't have to leave your house. Now that beats driving to NAPA.
Go TSC!!! :applause::applause::applause::applause::applause::wave: Too Funny, but that is a good point. Gas is high!:thumbsup:
   / NAPA Premium Heavy Duty Traactor Hydraulic and Transmission Fluid Specs #6
I hope its right, I'm picking up three buckets tommorow.:confused2:
Its kind of confusing, is says on the Material Safety Data Sheet
NAPA PREMIUM TRACTOR HYDRAULIC FLUID
Gravity
by ASTM D
1298
THF J20C
10W30
I don't get it, the Martins guys says 10-20 but the msds says 10-30?
Gravity
by ASTM D
1298
THF J20C
10W30
Call Terry from Martin above. He is one of the Oil techs who can answer your concerns. When I talked with him, He sure did not sound as if he was guessing. I would guess the product has changed to keep up with the new machine requirements, and they have not updated the MSDS sheet. I also emailed their customer service center asking for the most up to date full specs of the oil. I like stuff in black and white. I will post their reply.
   / NAPA Premium Heavy Duty Traactor Hydraulic and Transmission Fluid Specs #8
I am fortunate in that I drive right by both a tractor supply and NAPA on my way to work...
That is in addition to Advance Auto Parts, Auto Zone, Reilly's, Wal Mart, Lowes, Home Depot, Northern Tool, Harbor Freight...
No wonder I stay broke...LOL
In all seriousness, we've been using tractor supply products for years with good results...
NAPA carries excellent parts and oil also...
Lowes and Northern Tool would do me in. :dollarsign:
   / NAPA Premium Heavy Duty Traactor Hydraulic and Transmission Fluid Specs #10
Yeah NAPA and TSC are both great companies and both have good products.
When I had the Kubota the shop here wanted $400 for oil change at 50 hours, I did it for $150, a lot of difference, priced out oil and TSC was the best price.
Just a FYI, anytime doing shopping on the net at places do a search for "Coupon Codes" "name of store", most have a online coupon code that you enter at checkout, might be 10% off 15% or more, or free shipping, never know some don't have any codes some do. Just a tip to save a few coins.
   / NAPA Premium Heavy Duty Traactor Hydraulic and Transmission Fluid Specs #11
I have a question,say you have some hydro or gear failures during your warrenty period after you use TSC or NAPA fluids other than the Kioti branded fluids will Kioti stand behind the failure since you did not use there branded fluid?Just curious?
To my knowledge, Kioti does not have branded oil. They reference major brands in the manual.
   / NAPA Premium Heavy Duty Traactor Hydraulic and Transmission Fluid Specs #13
No, they cannot void the warranty as long as you use oil that meets the specs...
Magnuson
Warrantors cannot require that only branded parts be used with the product in order to retain the warranty.[7] This is commonly referred to as the "tie-in sales" provisions,[8] and is frequently mentioned in the context of third-party computer parts, such as memory and hard drives.
   / NAPA Premium Heavy Duty Traactor Hydraulic and Transmission Fluid Specs #14
What brand name does the Kioti dealers carry?Has anyone checked?
   / NAPA Premium Heavy Duty Traactor Hydraulic and Transmission Fluid Specs #15
The local kioti dealer near me uses Cub Cadet UTF, Which is not in the manuals BTW.
   / NAPA Premium Heavy Duty Traactor Hydraulic and Transmission Fluid Specs #16
My shop manual states,Daedong(TF65),Exxon(mobilfluid 423or424),Shell(donex-td/td plus)BP(tractran UTH)
   / NAPA Premium Heavy Duty Traactor Hydraulic and Transmission Fluid Specs #17
Mine as well coobie, I still haven't found any of those fluids locally, So what do ya do?
   / NAPA Premium Heavy Duty Traactor Hydraulic and Transmission Fluid Specs #18
Shell Donax TD is now called Shell Spirax S4 TXM. I found and bought two 5-gal containers at a local Walmart but never saw any more there after that. By the way, there are MANY Shell Spirax products and the S4TXM is the important part (T=tractor, X=multi vehicle/multi OEM, and M=low maintenance).
I have been to several dealers, and each uses different or multiple kinds of oil. You my notice in the chart from Kioti at the start of this thread, it says possible fluid.
I just emailed Kioti for a direct answer on the oil and warranty. I will let you know answer the ASAP. :)
FUTURE 60" PALLET FORK (A60432)
FUTURE 60" PALLET...
PALLET OF FILING CABINETS (A60432)
PALLET OF FILING...
2019 GALYEAN...
2022 Transcend Xplor 245RL 30ft. T/A Travel Trailer (A59231)
2022 Transcend...
(12) WOOD PALLETS (A60432)
(12) WOOD PALLETS...
PALLET OF 12IRON GATES (A58214)
PALLET OF 12IRON...
