pto jumping out
   / pto jumping out #1
dttrac
hernando,ms
63 4000 ford
pto is jumping out of gear. there is no in and out play on output shaft, does anybody know what internal parts of the pto, that normally goes out or can cause this problem on 63 ford 4000 diesel tractor
   / pto jumping out #2
Fairly common problem. Easiest is (but not recommended) to put a rubber bungee on the lever to hold it in gear. :) What is happening is the cogs on the collar inside the rear end housing that slide the PTO into gear have worn and rounded off and under load they are pushing the collar away, popping it out of gear. To correctly repair, the top cover of the rear end comes off (that is usually the 3pt lift assy), the pto shaft comes out the back and the shift assy can be removed then. It is held in place by 6 bolts around it's base. Sometimes the tractor will need to be split between the transmission and the rear end. Once the shift assy is out, it can be disassembled and inspected very easily. New or used parts are available, if you need help finding them let me know.
   / pto jumping out #3
pto popping out on a manual gear 4 cyl 4000 and no thrust play?
pull the pto shifter cover and make sure you are getting her engaged all the way. if yes and detent is good and still pops.. then yeah.. you will need to get in there.. very likely some wear .. repalcement parts are PLENTIFULL
   / pto jumping out #4
It's a lot faster to just loosen the pto shaft by pulling it out the back a few inches, removing the pto shift cover and replace the the coupler by feel through the round opening.
The splines on the pto shaft may also be worn or buggered up keeping the coupler from making full contact. I would pull it out and see if they need to be dressed with a small file.
   / pto jumping out #5
may even be rounded / chewed off as it walked out of engagement
2017 Chevrolet Tahoe (A52377)
2017 Chevrolet...
2014 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2014 DRAGON...
2004 FREIGHTLINER COLUMBIA (A53843)
2004 FREIGHTLINER...
5TH WHEEL HITCH (A53843)
5TH WHEEL HITCH...
2005 CHANDLER 500 BBL FRAC TANK (A53843)
2005 CHANDLER 500...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
