Is there anything I can spray on equipment to prevent winter rust?
   / Is there anything I can spray on equipment to prevent winter rust? #11
it may be good stuff.. I simply have not used it so can't comment on it.
   / Is there anything I can spray on equipment to prevent winter rust? #12
Another vote for Fluid Film. I will never be without a can again. Good stuff.
   / Is there anything I can spray on equipment to prevent winter rust? #13
Where is the best place to buy Fluid Film? I see the 11 3/4 oz spray on EBAY for $13.79 with free shipping.
   / Is there anything I can spray on equipment to prevent winter rust? #14
NAPA auto stores usually have Fluid Film in my area.
Tractor Supply, surprisingly, DOES NOT.
Spray cans are usually $8.99 to $11.99.
   / Is there anything I can spray on equipment to prevent winter rust? #15
Bought some at rural king the other day, $9.99 for aerosol can. I thought that was expensive, but apparently not.
   / Is there anything I can spray on equipment to prevent winter rust? #16
   / Is there anything I can spray on equipment to prevent winter rust? #17
I usually hit all the rust spots with a wire brush and then paint them with a rust conversion compound.
   / Is there anything I can spray on equipment to prevent winter rust? #18
might have to try me some of that..
Does it really work?
   / Is there anything I can spray on equipment to prevent winter rust? #20
I buy Fluid Film by the gallon. It is MUCH cheaper in that form than in spray cans. Remember that shaking it thins it out. If it sits it coagulates. I think the term is "pseudoplastic".
A cheap airless sprayer does a good job of spreading it. It is about the same consistency as latex paint. A disposable paint brush is even more economical.
I covered the moldboards of a shiny bright plow that sits out over the winter. In spring there was not a speck of rust on it. It wasn't used that year and the next year there was some rust in spring. The hot summer probably compromised the coating somewhat.
2014 DODGE CHARGER (A51406)
2014 DODGE CHARGER...
RHINO DB150 LOT NUMBER 73 (A53084)
RHINO DB150 LOT...
UNUSED EINGP MSC2030F 20' X 20' ALL-STEEL CARPORT (A54757)
UNUSED EINGP...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
2000 SCHWING P88 PORTABLE CONCRETE MIXER (A51247)
2000 SCHWING P88...
INSPECTION (A54865)
INSPECTION (A54865)
