How many implements/ attachments do you own?
   / How many implements/ attachments do you own? #101
Think this was done maybe 6 or 7 years ago. Here're mine:
o Soil ripper, which can be converted to a raised row maker.
o Bush hog
o MacKissic chipper/shredder
o Carryall
o Back blade
o FEL
Ralph
   / How many implements/ attachments do you own? #102
5' Brush Hog
5' Box Blade
6' PTO Blower
6' FEL mounted snow plow
6' Bucket
3PT log splitter
3PT PTO debris/leaf blower
3PT PTO 12K Generator
   / How many implements/ attachments do you own? #103
2 woods brushbull 7' and 6' brushhogs
1 Woods 8' rock rake
1 Kuhn disc mower
1 Kuhn tedder
1 Kuhn rake
1 FEL with bucket, forks and round bail spike
1 John Deer side delivery rake (old)
2 unknow name tedder (old)
1 IH hay conditioner
1 IH 8' harrow
1 New Holland hayliner baler
1 8'x16' landplane (homemade)
1 10' fisher snowplow (for a tractor)
1 8' frontier snowblower
2 Alamo rear mount boom mowers with 2 heads for each
I know I forgot something but that's the bulk even my (old) hay equipment still works its just on stand by.
   / How many implements/ attachments do you own? #104
Two tractors and 9 implements.
   / How many implements/ attachments do you own? #105
Here's my 3 years of collecting, 5' brush cutter , 5 ' box blade, Dearborn 2 bottom plow, ABO 22 6' disc,6' landscape rake, 1 shank sub-soil, post hole digger, and a fel up front.
   / How many implements/ attachments do you own? #106
Front End Loader
Grapple on FEL
60" dirt bucket with tooth bar
60" tiller
5.5' KK box frame disc - notched frt and rear
5' Box blade w/ 10 suitcase weights (for ballast box and grading)
5' rotary cutter
Woods Stump grinder
Herd Seeder
Itallian Fertilzer / seed spreader
Single Point Ripper
Ford Landscape Rake
Pallet forks
Pats EZ Change
PTO Extension (ok this was a cheap addn ;) )
EZ Flow Lime spreader
5 trailers
Post hole digger with 9" and 12" bits and extension.
Drag
Meyer 80" Snow blade conversion for FEL
......and I may have forgotten something?
   / How many implements/ attachments do you own? #107
Way late to the party, but here goes:
Loader attachments (3)
  • JD 96" bucket
  • Frontier AP13G Pallet Forks
  • Frontier AV20G Grapple
3pt attachments (14)
  • Woods BH1050 Backhoe
  • Woods SG100 Stump Grinder
  • Woods RM990 Finish Mower
  • Woods RB850 3 Way Hydraulic Blade
  • Woods LR108-2 Rake
  • Maschio H205 Tiller
  • Bush Hog 3209 Cutter
  • Vermeer 906 Chipper
  • Valby SGR76 3pt Grapple
  • Shaver 601H Post Digger
  • Tufline 8' Disc Harrow
  • Vicon Vari-Spreader MK-II 400
  • JD 45 16-3 Bottom Plow
  • GN Trailer Mover
   / How many implements/ attachments do you own? #108
Okay Roger... time to update your stats?
Wow, I guess I am below average.
I suppose I could count the weight barrel and weight block that I use on the back......
o well
I'll count them they would be attachments.
Half in jest... but you started it! :D
Okay here is the update.
People posted- 59
Implements/ Attachments- 742
Average- 13.25
   / How many implements/ attachments do you own? #112
People posted- 59
Average- 13.25
Aha! Very good... and it was higher than I expected but I am not a farmer. That amount to a lot of storage space per tractor!
I bet most of the stuff is kept outside. I think the average would be lower if more people replied.
Sent from my Samsung SPH-L710 using TractorByNet
   / How many implements/ attachments do you own? #114
I have to add 2 more attachments to my original count, sorry for messing up your stats :D
New to me RBT4096 rear blade and a new to me Woods power rake.
   / How many implements/ attachments do you own? #115
only 1 or 2..... per tractor.... ;)
   / How many implements/ attachments do you own? #116
Man you sooooooo spoiled :cool2:
   / How many implements/ attachments do you own? #117
All of mine are outside except for whatever is hooked to the tractors. And if it is very long, half of it is outside.
Larro
2 very nice additions to your collections. I'll add them the next time I update the stats.
Larro
My grapple, snow blade, and aerator are kept inside.
   / How many implements/ attachments do you own? #119
I seemed to have misplaced my snow removal implement. I haven't had to use it since that time we got almost an inch of the white stuff back in 1974. Maybe I just put it back in the corn crib once the porch was shoveled off. I can't remember.
Larro
   / How many implements/ attachments do you own? #120
Thanks Roger, it sure would be nice if I had a place indoors to store my equipment, but unfortunately it's all sitting outside.
2017 HAMM HD+140I DBL DRUM ROLLER (A60429)
2017 HAMM HD+140I...
5-6 YD BLUE LINE GRIZZLY SCREENER (A58214)
5-6 YD BLUE LINE...
2018 Husqvarna 21in. Push Mower (A59231)
2018 Husqvarna...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
2025 Ariens IKON 42 42in Zero Turn Commercial Mower (A59228)
2025 Ariens IKON...
UNUSED RAYTREE RMH680 HYD HAMMER (A60432)
UNUSED RAYTREE...
